[MOAB-dev] r4123 - MOAB/trunk/tools/mbcoupler
smithrm at mcs.anl.gov
Fri Sep 3 13:03:35 CDT 2010
Author: smithrm
Date: 2010-09-03 13:03:35 -0500 (Fri, 03 Sep 2010)
New Revision: 4123
Modified:
MOAB/trunk/tools/mbcoupler/Coupler.cpp
MOAB/trunk/tools/mbcoupler/Coupler.hpp
MOAB/trunk/tools/mbcoupler/ssn_test.cpp
Log:
Coupler.hpp, Coupler.cpp
o Added field function and number of integration points to normalize_subset().
o Added functions to generate integrated field values over groups of entities and
to apply normalization factors to groups of entities.
ssn_test.cpp
o Added tests for ElemUtil::integrate_trilinear_hex(),
Coupler::get_group_integ_vals() and
Coupler::apply_group_norm_factor().
Modified: MOAB/trunk/tools/mbcoupler/Coupler.cpp
--- MOAB/trunk/tools/mbcoupler/Coupler.cpp 2010-09-03 17:04:57 UTC (rev 4122)
+++ MOAB/trunk/tools/mbcoupler/Coupler.cpp 2010-09-03 18:03:35 UTC (rev 4123)
@@ -526,7 +526,9 @@
const char **tag_names,
int num_tags,
const char **tag_values,
- Coupler::IntegType integ_type)
+ Coupler::IntegType integ_type,
+ double (*field_fn) (double, double, double),
+ int num_integ_pts)
iMesh_Instance iMeshInst = reinterpret_cast<iMesh_Instance>(mbImpl);
int err;
@@ -541,7 +543,15 @@
tag_handles.push_back(th);
- return normalize_subset(m1_root_set, m2_root_set, norm_tag, &tag_handles[0], num_tags, tag_values, integ_type);
+ return normalize_subset(m1_root_set,
+ m2_root_set,
+ norm_tag,
+ &tag_handles[0],
+ num_tags,
+ tag_values,
+ integ_type,
+ (*field_fn),
+ num_integ_pts);
int Coupler::normalize_subset(iBase_EntitySetHandle &m1_root_set,
@@ -550,16 +560,18 @@
iBase_TagHandle *tag_handles,
int num_tags,
// ErrorCode result = MB_SUCCESS;
int err = iBase_SUCCESS;
// Get an iMesh_Instance from MBCoupler::mbImpl.
- iMesh_Instance iMeshInst = reinterpret_cast<iMesh_Instance>(mbImpl);
+// iMesh_Instance iMeshInst = reinterpret_cast<iMesh_Instance>(mbImpl);
// MASTER/SLAVE START #########################################################
- // Broadcast norm_tag, tag_handles, tag_values to procs
+ // Broadcast norm_tag, tag_handles, tag_values to procs???
