[MOAB-dev] buildbot failure in Fathom on moab-32bit-handles
    moab-dev at mcs.anl.gov
    Fri Aug 13 00:09:36 CDT 2010
The Fathomatic has detected a failed build of moab-32bit-handles on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-32bit-handles/builds/199
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
mv -f .deps/h5varlen.Tpo .deps/h5varlen.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o h5varlen h5varlen.o ../../src/libMOAB.la -lm
g++ -Wall -pipe -O2 -DNDEBUG -o h5varlen h5varlen.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -I.. -I./.. -I../../src -I../../src/io -I../../src/io/mhdf/include -I../../src -I../../src/parallel -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT h5sets_test.o -MD -MP -MF .deps/h5sets_test.Tpo -c -o h5sets_test.o h5sets_test.cpp
h5sets_test.cpp: In function 'void regression_mmiller_8_2010()':
h5sets_test.cpp:389: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [8], const char [13], int, const char [16])' is ambiguous
../TestUtil.hpp:332: note: candidates are: void check_equal(int, int, const char*, const char*, int, const char*)
../TestUtil.hpp:335: note:                 void check_equal(unsigned int, unsigned int, const char*, const char*, int, const char*)
../TestUtil.hpp:338: note:                 void check_equal(long int, long int, const char*, const char*, int, const char*)
../TestUtil.hpp:341: note:                 void check_equal(long unsigned int, long unsigned int, const char*, const char*, int, const char*)
../TestUtil.hpp:344: note:                 void check_equal(void*, void*, const char*, const char*, int, const char*) <near match>
../TestUtil.hpp:347: note:                 void check_equal(const char*, const char*, const char*, const char*, int, const char*) <near match>
../TestUtil.hpp:350: note:                 void check_equal(const std::string&, const std::string&, const char*, const char*, int, const char*) <near match>
../TestUtil.hpp:385: note:                 void check_equal(moab::ErrorCode, moab::ErrorCode, const char*, const char*, int, const char*) <near match>
h5sets_test.cpp:397: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [8], const char [13], int, const char [16])' is ambiguous
h5sets_test.cpp:405: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [8], const char [13], int, const char [16])' is ambiguous
h5sets_test.cpp:413: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [8], const char [13], int, const char [16])' is ambiguous
h5sets_test.cpp:421: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [8], const char [13], int, const char [16])' is ambiguous
sincerely,
 -The Fathomatic
