[MOAB-dev] r4084 - MOAB/trunk/src/io
    bmsmith6 at wisc.edu
    Wed Aug 11 17:57:45 CDT 2010
Author: bmsmith
Date: 2010-08-11 17:57:44 -0500 (Wed, 11 Aug 2010)
New Revision: 4084
Modified:
   MOAB/trunk/src/io/ReadNCDF.cpp
Log:
Print cub nodes that cannot be matched.
  This is needed because the user likely did not create the geometry, but needs to debug it.
  Mesh files are too large to fluidly manipulate in Cubit.
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp	2010-08-11 22:19:33 UTC (rev 4083)
+++ MOAB/trunk/src/io/ReadNCDF.cpp	2010-08-11 22:57:44 UTC (rev 4084)
@@ -1894,7 +1894,7 @@
   for(int i=0; i<numberNodes_loading; ++i) {
     int exo_id = ptr[i];
     CartVect exo_coords( orig_coords[0][i], orig_coords[1][i], orig_coords[2][i] );
-    EntityHandle cub_vert = -1;
+    EntityHandle cub_vert = 0;
     bool found_match = false;
     // by id
@@ -1933,7 +1933,7 @@
-      if(-1 != cub_vert) found_match = true;
+      if(0 != cub_vert) found_match = true;
     // If a match is found, update it with the deformed coords from the exo file.
@@ -1954,10 +1954,31 @@
       average_magnitude += magnitude;
     } else {
       ++lost;
-      std::cout << "cannot match exo vert " << exo_id << " " << exo_coords << std::endl;
+      std::cout << "cannot match exo node " << exo_id << " " << exo_coords << std::endl;
+  // Exo verts that could not be matched have already been printed. Now print the
+  // cub verts that could not be matched.
+  if(matched_cub_vert_id_map.size() < cub_verts.size()) {
+    Range unmatched_cub_verts = cub_verts;
+    for(std::map<int,EntityHandle>::const_iterator i=matched_cub_vert_id_map.begin();
+        i!=matched_cub_vert_id_map.end(); ++i) {
+      unmatched_cub_verts.erase( i->second );
+    for(Range::const_iterator i=unmatched_cub_verts.begin(); i!=unmatched_cub_verts.end(); ++i) {
+      int cub_id;
+      rval = mdbImpl->tag_get_data( mGlobalIdTag, &(*i), 1, &cub_id );
+      if(MB_SUCCESS != rval) return rval;
+      CartVect cub_coords;
+      rval = mdbImpl->get_coords( &(*i), 1, cub_coords.array() );
+      std::cout << "cannot match cub node " << cub_id << " " << cub_coords << std::endl;
+    std::cout << "  " << unmatched_cub_verts.size()
+              << " nodes from the cub file could not be matched." << std::endl;
