[MOAB-dev] Possible bug in moab::Core::get_coords
Roman Putanowicz putanowr at l5.pk.edu.pl
Tue Jul 27 21:46:57 CDT 2010
Dear All,
The same program, same data, two different machines and two different outputs.
Could someone of you, please, confirm the results so I can exclude
some stupid configuration bug (like wrong lib version though I have checked
that :)
In the attachment there is a simple program and data file.
The program finds the length of a perimeter of a skin of a triangle mesh.
I run it on two machines:
machne A:
gcc --version : gcc (Debian 4.4.4-6) 4.4.4
uname -srm    : Linux 2.6.32-trunk-686 i686
machine B:
gcc --version : gcc (Debian 4.3.2-1.1) 4.3.2
uname -srm    : Linux 2.6.26-2-amd64 x86_64
MOAB svn version 4070
Running the program I got:
   Machine A:        |            Machine B
V: 1 2               |          V: 1 2
0 0 0 1 0 0          |          0 0 0 1 0 0
V: 2 3               |          V: 2 3
1 0 0 1 1 0          |          1 0 0 1 1 0
V: 3 4               |          V: 3 4
1 1 0 0 1 0          |          1 1 0 0 1 0
V: 1 4               |          V: 1 4
0 1 0 0 1 0          |          0 0 0 0 1 0         <<--------- BINGO
Perim length: 3      |          Perim length: 4
For the test data (unit square mesh) correct anser is of course B.
( BTW why the vertices of the last edge are 1 4 and not 4 1 ? )
Compiling the program
g++ -I INC_PATH -L LIB_PATH coordsBug.cxx -lMOAB -o coordsBug
Running:
coordsBug two_triangles.vtk
Thanks in advance for any hint.
Roman
Roman Putanowicz, PhD  < putanowr at l5.pk.edu.pl  >
Institute for Computational Civil Engng (L-5)
Dept. of Civil Engng, Cracow Univ. of Technology
www.l5.pk.edu.pl, tel. +48 12 628 2569, fax 2034
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100728/1c0402f7/attachment.cxx>
# vtk DataFile Version 3.0
MOAB 3.99 (Alpha)
ASCII
DATASET UNSTRUCTURED_GRID
POINTS 4 double
0 0 0
1 0 0
1 1 0
0 1 0
CELLS 2 8
3 0 1 2
3 0 2 3
CELL_TYPES 2
5
5
