[MOAB-dev] r4061 - in MOAB/trunk: src/io tools/dagmc
bmsmith6 at wisc.edu
Wed Jul 21 09:36:43 CDT 2010
Author: bmsmith
Date: 2010-07-21 09:36:42 -0500 (Wed, 21 Jul 2010)
New Revision: 4061
Modified:
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/tools/dagmc/cub2h5m.cc
Log:
ReadNCDF: Manually allocate exo_conn because it doesn't fit on stack.
Get time of time step from file.
cub2h5m: Summarize volume change for each material due to deformation.
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp 2010-07-20 20:05:47 UTC (rev 4060)
+++ MOAB/trunk/src/io/ReadNCDF.cpp 2010-07-21 14:36:42 UTC (rev 4061)
@@ -1720,6 +1720,21 @@
return MB_FAILURE;
+ // get the time
+ NcVar *times_ptr = ncFile->get_var("time_whole");
+ if(NULL==times_ptr || !times_ptr->is_valid()) {
+ std::cout << "ReadNCDF: unable to get time variable" << std::endl;
+ } else {
+ double times[max_time_steps];
+ NcBool status = times_ptr->get(×[0], max_time_steps);
+ if(0==status) {
+ std::cout << "ReadNCDF: unable to get time array" << std::endl;
+ } else {
+ std::cout << " Step " << time_step << " is at " << times[time_step-1]
+ << " seconds" << std::endl;
//read in the node_num_map .
std::vector<int> ptr(numberNodes_loading);
@@ -1944,7 +1959,7 @@
if(0 != lost) {
std::cout << "Error: " << lost << " nodes from the exodus file could not be matched."
<< std::endl;
- return MB_FAILURE;
+ //return MB_FAILURE;
std::cout << " maximum node displacement magnitude: " << max_magnitude
<< " cm" << std::endl;
@@ -2068,12 +2083,14 @@
// Get the number of nodes per element
unsigned int nodes_per_element = ExoIIUtil::VerticesPerElement[(*i).elemType];
- // read the connectivity into that memory, this will take only part of the array
- // 1/2 if sizeof(EntityHandle) == 64 bits.
- int exo_conn[i->numElements][nodes_per_element];
- NcBool status = temp_var->get( &exo_conn[0][0], i->numElements, nodes_per_element);
+ // read the connectivity into that memory.
+ //int exo_conn[i->numElements][nodes_per_element];
+ int *exo_conn = new int [i->numElements*nodes_per_element];
+ //NcBool status = temp_var->get( &exo_conn[0][0], i->numElements, nodes_per_element);
+ NcBool status = temp_var->get( &exo_conn[0], i->numElements, nodes_per_element);
if (0 == status) {
std::cout << "ReadNCDF: Problem getting connectivity." << std::endl;
+ delete[] exo_conn;
