[MOAB-dev] r4053 - MOAB/trunk/src/io
hongjun at mcs.anl.gov
Wed Jul 14 12:23:59 CDT 2010
Author: hongjun
Date: 2010-07-14 12:23:59 -0500 (Wed, 14 Jul 2010)
New Revision: 4053
Modified:
MOAB/trunk/src/io/WriteVtk.cpp
Log:
o bug fixed, "get_connectivity" function needs vector storage allocated as an argument
Modified: MOAB/trunk/src/io/WriteVtk.cpp
--- MOAB/trunk/src/io/WriteVtk.cpp 2010-07-13 18:24:22 UTC (rev 4052)
+++ MOAB/trunk/src/io/WriteVtk.cpp 2010-07-14 17:23:59 UTC (rev 4053)
@@ -196,13 +196,12 @@
for (Range::const_iterator e = elems.begin(); e != elems.end(); ++e)
- const EntityHandle* conn;
- int conn_len;
- rval = mbImpl->get_connectivity( *e, conn, conn_len );
+ std::vector<EntityHandle> connect;
+ rval = mbImpl->get_connectivity( &(*e), 1, connect );
if (MB_SUCCESS != rval) return rval;
- for (int i = 0; i < conn_len; ++i)
- nodes.insert( conn[i] );
+ for (int i = 0; i < connect.size(); ++i)
+ nodes.insert( connect[i] );
@@ -256,12 +255,14 @@
EntityType type = mbImpl->type_from_handle(*i);
if (!VtkUtil::get_vtk_type(type, CN::VerticesPerEntity(type))) continue;
- int conn_len;
- rval = mbImpl->get_connectivity( *i, conn, conn_len );
+ rval = mbImpl->get_connectivity( &(*i), 1, connect );
return rval;
- num_uses += conn_len;
+ num_uses += connect.size();
stream << "CELLS " << num_elems << ' ' << num_uses << std::endl;
@@ -275,9 +276,10 @@
EntityType type = TYPE_FROM_HANDLE(*i);
// Get element connectivity
- int conn_len;
+ int conn_len = connect.size();
