[MOAB-dev] r4016 - MOAB/trunk/tools/dagmc
Tim Tautges tautges at mcs.anl.gov
Wed Jun 23 23:46:50 CDT 2010
Although moab.make and cgm.make can be described as being for convenience, I do strongly recommend they be used most of
the time.  In general, I think that's the only way you'll be able to guarantee linking succeeds.  The only other
recommended course of action is to use libtool, which in theory finds the various libs a lib depends on.
As for the difficulty of tracking this down, did you try running this under valgrind?  That should warn about the RefXxx
being referenced before being set.
- tim
On 06/23/2010 11:33 PM, Paul Wilson wrote:
> Alas, I find myself more convinced of the others' view.
> It seems dangerous for the public interface to depend on a define, thus
> allowing the library to be built with one interface and the calling app
> to be built expecting another. (Perhaps in an earlier email to me) Steve
> pointed out that moab.make is more of a convenience than a requirement
> for building apps with MOAB. We could include relevant defines in
> moab.make (one way or another) but it still allows for the possibility
> that this inconsistency arises when a developer decides not to use
> moab.make.
> Furthermore, it was a particularly difficult inconsistency to track down
> as there were no compile-, link-, or runtime errors - just the wrong
> answer when the code ran!
> Note, also, that CGM defines are still available after this fix, they
> just don't change the public interface.
> Some other ideas:
>     * Modify the header (eg. DagMC.hpp) at install-time to install a
>       header that is unconditionally the same as the conditions used in
>       building MOAB. That is, parse the header at install time with the
>       same macros as used to build so that the interface is consistent
>       and unambiguous
>     * <begin kludge (I'm brainstorming here)>Declare a function
>       prototype and/or invoke a function within the conditional code
>       that will at least raise a link-time error when the inconsistency
>       arises</kludge>
> Paul
> Tim Tautges wrote:
>> I agree with Paul, if MOAB is compiled with CGM on, the CGM defines
>> etc. should be available to client apps, probably via inclusion of
>> cgm.make in moab.make.
>> Jim, could you investigate? Thanks.
>> - tim
>> On 06/23/2010 04:19 PM, Paul Wilson wrote:
>>> Hi Steve,
>>> Thanks again for finding this, but the more I think about it, I wonder
>>> if this is the right solutions.
>>> It is theoretically possible to build MOAB/DAGMC apps with no reference
>>> to CGM whatsoever. Under those circumstances, RefEntity will never be
>>> defined beyond the single declaration in DagMC.hpp. Is this OK? Wouldn't
>>> it be better to set the CGM macro in moab.make for inclusion in other
>>> apps?
>>> Paul
>>> sjackson at cae.wisc.edu wrote:
>>>> Author: sjackson
>>>> Date: 2010-06-23 14:44:46 -0500 (Wed, 23 Jun 2010)
>>>> New Revision: 4016
>>>> Modified:
>>>> MOAB/trunk/tools/dagmc/DagMC.hpp
>>>> Log:
>>>> Fix a very old, but recently symptomatic, bug in DagMC.
>>>> When MOAB is built with CGM, the macro "CGM" is defined. Until now,
>>>> this caused an extra data member to be included in the DagMC class.
>>>> However, client code compiling against DagMC does not define the CGM
>>>> macro (the macro is not exported to moab.make). This means a client
>>>> compiling against DagMC.hpp can wind up with an incorrect map of the
>>>> data members in a DagMC object.
>>>> This hasn't surfaced as a problem before because the conditionally-
>>>> included data member was declared *after* all other client-facing
>>>> data members. The reordering of data members in r4006 exposed the
>>>> problem.
>>>> The easy solution (which I've taken) is to simply remove the checks
>>>> from the header file. If CGM is not available, the extra declarations
>>>> are harmless (and DagMC gets one extra unused std::vector).
>>>> Moral: Beware of #ifdefs in public headers, particularly if they
>>>> check for macros that client code may not know about.
>>>> Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
>>>> --- MOAB/trunk/tools/dagmc/DagMC.hpp 2010-06-22 18:15:50 UTC (rev 4015)
>>>> +++ MOAB/trunk/tools/dagmc/DagMC.hpp 2010-06-23 19:44:46 UTC (rev 4016)
>>>> @@ -12,9 +12,7 @@
>>>> #include "moab/OrientedBoxTreeTool.hpp"
>>>> -#ifdef CGM
>>>> class RefEntity;
>>>> -#endif
>>>> namespace moab {
>>>> @@ -349,10 +347,8 @@
>>>> // entity index (contiguous 1-N indices) indexed like rootSets are
>>>> std::vector<int> entIndices;
>>>> -#ifdef CGM
>>>> // corresponding geometric entities indexed like rootSets are
>>>> std::vector<RefEntity *> geomEntities;
>>>> -#endif
>>>> // metadata
>>>> Tag matTag, densTag, bcTag, impTag, tallyTag;
> Paul Wilson
> Paul P.H. Wilson              419 Engineering Research Building
> wilsonp at engr.wisc.edu                        1500 Engineering Dr
> ph/fax: 608/263-0807                          Madison, WI 53706
>             My calendar:http://bit.ly/pphw-calendar
>         Computational Nuclear Engineering Research Group
>                 http://cnerg.engr.wisc.edu
>            Associate Professor, Nuclear Engineering
>                Engineering Physics Department
>                 http://www.engr.wisc.edu/ep
>          Chair, Energy Analysis&  Policy Certificate
>           Nelson Institute for Environmental Studies
>                  http://nelson.wisc.edu/eap/
>            Contributing to the joy and improvement
>                    of all those around me
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
