[MOAB-dev] r4016 - MOAB/trunk/tools/dagmc
    Paul Wilson
    wilsonp at engr.wisc.edu
    Wed Jun 23 16:19:56 CDT 2010
Hi Steve,
Thanks again for finding this, but the more I think about it, I wonder
if this is the right solutions.
It is theoretically possible to build MOAB/DAGMC apps with no reference
to CGM whatsoever.  Under those circumstances, RefEntity will never be
defined beyond the single declaration in DagMC.hpp.  Is this OK?
Wouldn't it be better to set the CGM macro in moab.make for inclusion in
other apps?
Paul
sjackson at cae.wisc.edu wrote:
> Author: sjackson
> Date: 2010-06-23 14:44:46 -0500 (Wed, 23 Jun 2010)
> New Revision: 4016
> Modified:
>    MOAB/trunk/tools/dagmc/DagMC.hpp
> Log:
> Fix a very old, but recently symptomatic, bug in DagMC.
> When MOAB is built with CGM, the macro "CGM" is defined.  Until now,
> this caused an extra data member to be included in the DagMC class.
> However, client code compiling against DagMC does not define the CGM
> macro (the macro is not exported to moab.make).  This means a client
> compiling against DagMC.hpp can wind up with an incorrect map of the
> data members in a DagMC object.
> This hasn't surfaced as a problem before because the conditionally-
> included data member was declared *after* all other client-facing
> data members.  The reordering of data members in r4006 exposed the
> problem.
> The easy solution (which I've taken) is to simply remove the checks
> from the header file.  If CGM is not available, the extra declarations
> are harmless (and DagMC gets one extra unused std::vector).
> Moral: Beware of #ifdefs in public headers, particularly if they
> check for macros that client code may not know about.
> Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
> --- MOAB/trunk/tools/dagmc/DagMC.hpp	2010-06-22 18:15:50 UTC (rev 4015)
> +++ MOAB/trunk/tools/dagmc/DagMC.hpp	2010-06-23 19:44:46 UTC (rev 4016)
> @@ -12,9 +12,7 @@
>  #include "moab/OrientedBoxTreeTool.hpp"
> -#ifdef CGM
>  class RefEntity;
> -#endif
>  namespace moab {
> @@ -349,10 +347,8 @@
>      // entity index (contiguous 1-N indices) indexed like rootSets are
>    std::vector<int> entIndices;
> -#ifdef CGM
>      // corresponding geometric entities indexed like rootSets are
>    std::vector<RefEntity *> geomEntities;
> -#endif
>    // metadata
>    Tag matTag, densTag, bcTag, impTag, tallyTag;
Paul Wilson
Paul P.H. Wilson              419 Engineering Research Building
wilsonp at engr.wisc.edu                       1500 Engineering Dr
ph/fax: 608/263-0807                          Madison, WI 53706
           My calendar: http://bit.ly/pphw-calendar
       Computational Nuclear Engineering Research Group
               http://cnerg.engr.wisc.edu
          Associate Professor, Nuclear Engineering
              Engineering Physics Department
               http://www.engr.wisc.edu/ep
        Chair, Energy Analysis & Policy Certificate
         Nelson Institute for Environmental Studies
                http://nelson.wisc.edu/eap/
          Contributing to the joy and improvement
                  of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100623/cc05b4ab/attachment.bin>
