[MOAB-dev] r4003 - MOAB/trunk/src/parallel
smithrm at mcs.anl.gov smithrm at mcs.anl.gov
Wed Jun 9 17:17:19 CDT 2010
Author: smithrm
Date: 2010-06-09 17:17:19 -0500 (Wed, 09 Jun 2010)
New Revision: 4003
Modified:
   MOAB/trunk/src/parallel/ReadParallel.cpp
Log:
o Fix MOAB ticket #30 where geometric vertex sets were not being partitioned.
  Specifically, after deleting non-local entities the sets that contained those
  entities were not being removed from the partition.
Modified: MOAB/trunk/src/parallel/ReadParallel.cpp
--- MOAB/trunk/src/parallel/ReadParallel.cpp	2010-06-09 18:03:03 UTC (rev 4002)
+++ MOAB/trunk/src/parallel/ReadParallel.cpp	2010-06-09 22:17:19 UTC (rev 4003)
@@ -656,6 +656,18 @@
                                            &all_sets);
   RR("Failure gathering related entities.");
+    // Collect the empty sets from all_sets
+  Range orig_empty_sets;
+  for (Range::iterator rit = all_sets.begin();
+       rit != all_sets.end(); rit++) {
+    int num_ents;
+    result = mbImpl->get_number_entities_by_handle(*rit, num_ents);
+    RR("Failure getting number of entities.");
+    if (num_ents == 0)
+      orig_empty_sets.insert(*rit);
     // get pre-existing entities
   Range file_ents;
   result = mbImpl->get_entities_by_handle(file_set, file_ents);
@@ -681,6 +693,20 @@
     RR("Failure removing deletable entities.");
+    // Collect the empty sets from keepable_sets and add to deletable_sets
+  for (Range::iterator rit = keepable_sets.begin();
+       rit != keepable_sets.end(); rit++) {
+    int num_ents;
+      deletable_sets.insert(*rit);
+    // Subtract the original empty_sets from deletable_sets.
+  deletable_sets = subtract(deletable_sets, orig_empty_sets);
   myDebug.tprint( 2, "Deleting deletable entities.\n" );
   if (myPcomm->proc_config().proc_rank() == 0) {
