[MOAB-dev] r3998 - MOAB/trunk/src
    kraftche at cae.wisc.edu
    Fri Jun  4 15:16:35 CDT 2010
Author: kraftche
Date: 2010-06-04 15:16:35 -0500 (Fri, 04 Jun 2010)
New Revision: 3998
Modified:
   MOAB/trunk/src/MBEntityType.h
Log:
fix doxygen documentation (move docs for enum back to right before enum def)
Modified: MOAB/trunk/src/MBEntityType.h
--- MOAB/trunk/src/MBEntityType.h	2010-06-04 17:56:14 UTC (rev 3997)
+++ MOAB/trunk/src/MBEntityType.h	2010-06-04 20:16:35 UTC (rev 3998)
@@ -16,12 +16,6 @@
 #ifndef MB_ENTITY_TYPE_H
 #define MB_ENTITY_TYPE_H
-/*! Entity types defined in MOAB and MBCN
- *  The ordering here must ensure that all element types are
- *  grouped together and all elements of similar dimension are
- *  grouped together.
 /* This file can be used to define several different things.
  * A) If included in C code (not C++), it defines:
@@ -65,6 +59,12 @@
 # else /* __cplusplus */
 # define MOAB_ENTITY_TYPE_NAME MBEntityType
 #endif /* __cplusplus */
+/*! Entity types defined in MOAB and MBCN
+ *  The ordering here must ensure that all element types are
+ *  grouped together and all elements of similar dimension are
+ *  grouped together.
 enum MOAB_ENTITY_TYPE_NAME
   MBVERTEX = 0, /**< Mesh Vertex AKA node */
