[MOAB-dev] r3967 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Wed May 26 16:52:58 CDT 2010
Author: kraftche
Date: 2010-05-26 16:52:58 -0500 (Wed, 26 May 2010)
New Revision: 3967
Modified:
MOAB/trunk/src/io/WriteHDF5.hpp
Log:
fix compile error on IBM
Modified: MOAB/trunk/src/io/WriteHDF5.hpp
--- MOAB/trunk/src/io/WriteHDF5.hpp 2010-05-26 21:28:03 UTC (rev 3966)
+++ MOAB/trunk/src/io/WriteHDF5.hpp 2010-05-26 21:52:58 UTC (rev 3967)
@@ -46,6 +46,16 @@
protected:
+ /** The type to use for entity IDs w/in the file.
+ * NOTE: If this is changed, the value of id_type
+ * MUST be changed accordingly.
+ typedef EntityHandle id_t;
+ /** HDF5 type corresponding to type of id_t */
+ static const hid_t id_type;
struct ExportType
//! The type of the entities in the range
@@ -125,16 +135,6 @@
static WriterIface* factory( Interface* );
- /** The type to use for entity IDs w/in the file.
- * NOTE: If this is changed, the value of id_type
- * MUST be changed accordingly.
- typedef EntityHandle id_t;
- /** HDF5 type corresponding to type of id_t */
- static const hid_t id_type;
WriteHDF5( Interface* iface );
virtual ~WriteHDF5();
