[MOAB-dev] r3964 - MOAB/trunk/src/io
wilsonp at engr.wisc.edu
Wed May 26 15:04:27 CDT 2010
Author: wilsonp
Date: 2010-05-26 15:04:27 -0500 (Wed, 26 May 2010)
New Revision: 3964
Modified:
MOAB/trunk/src/io/ReadCGM.cpp
Log:
Always store the faceting tolerance and geometry absolute resolution on the mesh. If no
file_set is provided create a separate set that is tagged with these parameters.
It can be recovered upon reading by searching for all sets that have that tag.
Modified: MOAB/trunk/src/io/ReadCGM.cpp
--- MOAB/trunk/src/io/ReadCGM.cpp 2010-05-26 19:28:27 UTC (rev 3963)
+++ MOAB/trunk/src/io/ReadCGM.cpp 2010-05-26 20:04:27 UTC (rev 3964)
@@ -151,13 +151,22 @@
if(MB_SUCCESS == opts.match_option(name,value))
act_att = false;
- // tag the file_set with the faceting_tol and geometry absolute resolution
- if (file_set) {
- rval = mdbImpl->tag_set_data( faceting_tol_tag, file_set, 1, &faceting_tol );
- if(MB_SUCCESS != rval) return rval;
- rval = mdbImpl->tag_set_data( geometry_resabs_tag, file_set, 1, &GEOMETRY_RESABS );
+ // always tag with the faceting_tol and geometry absolute resolution
+ // if file_set is defined, use that, otherwise create a set
+ EntityHandle facet_tol_tag_set;
+ if (NULL == file_set) {
+ EntityHandle temp_tag_set;
+ rval = mdbImpl->create_meshset( MESHSET_SET, temp_tag_set );
+ if (MB_SUCCESS != rval) return rval;
+ facet_tol_tag_set = temp_tag_set;
+ } else {
+ facet_tol_tag_set = *file_set;
+ rval = mdbImpl->tag_set_data( faceting_tol_tag, &facet_tol_tag_set, 1, &faceting_tol );
+ if(MB_SUCCESS != rval) return rval;
+ rval = mdbImpl->tag_set_data( geometry_resabs_tag, &facet_tol_tag_set, 1, &GEOMETRY_RESABS );
// CGM data
std::map<RefEntity*,EntityHandle> entmap[5]; // one for each dim, and one for groups
