[MOAB-dev] r3957 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Tue May 25 14:31:43 CDT 2010
Author: kraftche
Date: 2010-05-25 14:31:43 -0500 (Tue, 25 May 2010)
New Revision: 3957
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.cpp
Log:
Write node coordinates in interleaved format.
Using HDF5 chunked IO to enable the on-disk layout of node coordinates to
be column-major results in deadlocks when writing in parallel on cosmea.
So this is plan B: just write the node coorindates in interleaved format.
This requires extra buffering of node coordinate data when writing, but
will hopefully avoid the long read times observed on cosmea.
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2010-05-25 19:22:52 UTC (rev 3956)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2010-05-25 19:31:43 UTC (rev 3957)
@@ -54,6 +54,7 @@
namespace moab {
+#undef BLOCKED_COORD_IO
#define READ_HDF5_BUFFER_SIZE (40*1024*1024)
@@ -1042,7 +1043,6 @@
if (is_error(status))
return error(MB_FAILURE);
EntityHandle handle;
std::vector<double*> arrays(dim);
rval = readUtil->get_node_coords( dim, (int)node_file_ids.size(), 0, handle, arrays );
@@ -1051,33 +1051,62 @@
mhdf_closeData( filePtr, data_id, &status );
return error(rval);
+#ifndef BLOCKED_COORD_IO
+ double* buffer = (double*)dataBuffer;
+ long chunk_size = bufferSize / (3*sizeof(double));
+ long coffset = 0;
+#endif
// read blocks of coordinates
Range::const_pair_iterator p;
for (p = node_file_ids.const_pair_begin(); p != node_file_ids.const_pair_end(); ++p)
- long count = p->second - p->first + 1;
+ long remaining = p->second - p->first + 1;
long offset = p->first - fileInfo->nodes.start_id;
- debug_track.record_io( offset, count );
- dbgOut.tprintf(4,"Reading nodes [%ld,%ld]\n", offset, offset+count-1);
+ if (!idMap.insert( p->first, handle, remaining ).second) {
+ mhdf_closeData( filePtr, data_id, &status );
+ return error(MB_FAILURE);
+ handle += remaining;
+#ifdef BLOCKED_COORD_IO
+ debug_track.record_io( offset, remaining );
+ dbgOut.tprintf(4,"Reading nodes [%ld,%ld]\n", offset, offset+remaining-1);
