[MOAB-dev] r3948 - in MOAB/trunk: src/io src/parallel test/parallel
kraftche at cae.wisc.edu
Tue May 25 09:14:44 CDT 2010
Author: kraftche
Date: 2010-05-25 09:14:43 -0500 (Tue, 25 May 2010)
New Revision: 3948
Modified:
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/test/parallel/mhdf_parallel.c
Log:
disable previos change, as it is causing HDF5 writer to hang
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-25 13:54:03 UTC (rev 3947)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-25 14:14:43 UTC (rev 3948)
@@ -2177,7 +2177,7 @@
if (nodeSet.range.size()) {
nodeSet.total_num_ents = nodeSet.range.size();
handle = mhdf_createNodeCoords( filePtr, dimension, nodeSet.total_num_ents,
- &first_id, true, &status );
+ &first_id, false, &status );
CHK_MHDF_ERR_0(status);
mhdf_closeData( filePtr, handle, &status );
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2010-05-25 13:54:03 UTC (rev 3947)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2010-05-25 14:14:43 UTC (rev 3948)
@@ -837,7 +837,7 @@
total += node_counts[i];
nodeSet.total_num_ents = total;
- hid_t handle = mhdf_createNodeCoords( filePtr, dimension, total, &first_id_and_max_count[0], true, &status );
+ hid_t handle = mhdf_createNodeCoords( filePtr, dimension, total, &first_id_and_max_count[0], false, &status );
CHECK_HDF(status);
Modified: MOAB/trunk/test/parallel/mhdf_parallel.c
--- MOAB/trunk/test/parallel/mhdf_parallel.c 2010-05-25 13:54:03 UTC (rev 3947)
+++ MOAB/trunk/test/parallel/mhdf_parallel.c 2010-05-25 14:14:43 UTC (rev 3948)
@@ -70,7 +70,7 @@
mhdf_writeHistory( file, history, history_size, &status );
CHECK(status);
- data = mhdf_createNodeCoords( file, 3, num_nodes, &junk, 1, &status );
+ data = mhdf_createNodeCoords( file, 3, num_nodes, &junk, 0, &status );
CHECK(status);
mhdf_closeData( file, data, &status );
CHECK(status);
