[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Tue May 25 00:13:49 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/159
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
touch FCDefs.h.in
cd .. && /bin/sh ./config.status src/FCDefs.h
config.status: creating src/FCDefs.h
config.status: src/FCDefs.h is unchanged
list='parallel io . oldinc'; for subdir in $list; do \
	  if test "$subdir" = .; then :; else \
	    test -d "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/src/$subdir" \
	    || /bin/mkdir -p "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/src/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/src && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        top_distdir="$top_distdir" \
	        distdir="$distdir/$subdir" \
		am__remove_distdir=: \
		am__skip_length_check=: \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/src/parallel'
cd ../.. && /bin/sh /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/config/missing --run autoheader
rm -f stamp-h4
touch moab_mpi_config.h.in
cd ../.. && /bin/sh ./config.status src/parallel/moab_mpi_config.h
config.status: creating src/parallel/moab_mpi_config.h
config.status: src/parallel/moab_mpi_config.h is unchanged
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/src/io'
list='. mhdf'; for subdir in $list; do \
	    test -d "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/src/io/$subdir" \
	    || /bin/mkdir -p "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/src/io/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/src/io && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/src/io/mhdf'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/src/oldinc'
make[2]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/MeshFiles'
make[2]: *** No rule to make target `cinglecyl.h5m', needed by `distdir'.  Stop.
sincerely,
 -The Fathomatic
