[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Sun May 23 00:15:45 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/157
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
checking if qvdual is to be built... no
checking if mbsize is to be built... yes
checking if mbskin is to be built... yes
checking if mbtagprop is to be built... yes
checking if mbmem is to be built... yes
checking if mcnpmit is to be built... no
checking if mbcoupler is to be built... no
checking if spheredecomp is to be built... yes
checking if mbsurfplot is to be built... yes
checking if mbzoltan is to be built... no
checking if dagmc is to be built... yes
checking if gsets is to be built... yes
checking if mbdepth is to be built... yes
checking if refiner is to be built... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating src/Makefile
config.status: creating src/io/Makefile
config.status: creating src/io/mhdf/Makefile
config.status: creating src/parallel/Makefile
config.status: creating src/oldinc/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating test/io/Makefile
config.status: creating test/parallel/Makefile
config.status: creating test/oldinc/Makefile
config.status: creating itaps/Makefile
config.status: creating itaps/imesh/Makefile
config.status: creating itaps/imesh/iMesh-Defs.inc
config.status: creating itaps/igeom/Makefile
config.status: creating itaps/igeom/iGeom-Defs.inc
config.status: creating tools/Makefile
config.status: creating tools/refiner/Makefile
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbcoupler/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/mcnpmit/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating doc/Makefile
config.status: creating doc/user.dox
config.status: creating examples/Makefile
config.status: creating examples/examples.make
config.status: creating examples/simple/makefile
config.status: error: cannot find input file: MeshFiles/Makefile.in
sincerely,
 -The Fathomatic
