[MOAB-dev] r3941 - in MOAB/trunk: MeshFiles/unittest/io src/io
    tautges at mcs.anl.gov
    Fri May 21 18:55:08 CDT 2010
Author: tautges
Date: 2010-05-21 18:55:08 -0500 (Fri, 21 May 2010)
New Revision: 3941
Added:
   MOAB/trunk/MeshFiles/unittest/io/cube_5x5.lnx64.ccmg
Modified:
   MOAB/trunk/src/io/ReadCCMIO.cpp
   MOAB/trunk/src/io/ReadCCMIO.hpp
   MOAB/trunk/src/io/WriteCCMIO.cpp
   MOAB/trunk/src/io/WriteCCMIO.hpp
Log:
Treat material and neumann sets properly on write and read.
Added: MOAB/trunk/MeshFiles/unittest/io/cube_5x5.lnx64.ccmg
--- MOAB/trunk/MeshFiles/unittest/io/cube_5x5.lnx64.ccmg	                        (rev 0)
+++ MOAB/trunk/MeshFiles/unittest/io/cube_5x5.lnx64.ccmg	2010-05-21 23:55:08 UTC (rev 3941)
@@ -0,0 +1,36 @@
+@(#)ADF Database>A02011>AdF0Fri Feb  6 15:42:07 2009    AdF1Fri Feb  6 15:42:07 2009    AdF2LBAdF3010204080408080808080808AdF400000000010A000000240B2A0000000000BA000000001000AdF5fCbt000000220AF2000000000EB7000000120BBC000000050486000000001000000000001000FcteNoDeADF MotherNode                  Root Node of ADF File           00000005000000080000000002F6MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeGeneral                         General                         0000000200000008000000000560MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb000000000466General                         000000000200States                          0000000007F7Meshes                          0000000102ACMaps                            000000010702ProblemDescriptions             0000002
 20432unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeVersion                         Version                         0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000006D4TaiLSNTb0000000006D0Version                         00000000046ATitle                           0000000006ECunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000006E8P  dEnDNoDeTitle                           Title                           0000000000000000000000001000C1                              000000000000000000000000000000000000000000000000000000000000000000000000000000
 0000000000000000000000010000000007E2TaiLDaTa0000000007F3 dEnDNoDeStates                          state                           00000001000000080000000009E3MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDedefault                         state                           0000000200000008000000000C4DMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb000000000B53default                         0000000008EDunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeProcessor-1                     processor
     0000000600000008000000010000MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb000000000DBDProcessor-1                     000000000B57ProblemDescription              000000240A1Dunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeCreatingProgram                 CreatingProgram                 0000000000000000000000001000C1                              010000001200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000010174TaiLFreE000000000FFC000000001000xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCSNTb000000010170CreatingProgram                 000000000DC1GeometryTag                     00000001019AVerticesFile                    000000220000VerticesId                      00000022010BTopologyFile                    000000220219TopologyId                      000000220324unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000010196pro-STAR  4.09.000dEnDNoDeGeometryTag                     GeometryTag                     0000000000000000000000001000C1                              010000000800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000010290TaiLDaTa0000000102A879901974dEnDNoDeMeshes                          Meshes                          0000000200000008000000010498MT                              0000000000000000000000000000000000000
 00000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeVertices-1                      vertices                        0000000400000008000000020C36MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb000000010608Vertices-1                      0000000103A2FaceBasedTopology-1             00000001060Cunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeFaceBasedTopology-1             topology                        00000006000000080000000902A4MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeMaps                            map
                         00000006000000080000000108EEMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeMap-1                           map                             0000000300000008000000010B58MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb000000010A5EMap-1                           0000000107F8Map-2                           000000090418Map-3                           0000000B07ACMap-4                           0000001A0730Map-5                           0000001E0B5CMap-6                           00000020064Eunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeLabel                           Label                           0000000000000000000000001000C1                              010000000A0000000000000000000000000000000
 0000000000000000000000000000000000000000000000000000000000001000000010CCCTaiLSNTb000000010CC8Label                           000000010A62MaximumMappedId                 000000010CEAIdMap                           000000010DF8unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000010CE6Vertex mapdEnDNoDeMaximumMappedId                 MaximumMappedId                 0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000010DE0TaiLDaTa000000010DF4Ø   dEnDNoDeIdMap                           IdMap                           0000000700000008000000020000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000201
 90TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000020174TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzSNTb000000020170ExtendedSize                    000000010EEEExtendedData-1                  000000020224ExtendedData-2                  0000000203AEExtendedData-3                  000000020538ExtendedData-4                  0000000206C2ExtendedData-5                  00000002084CExtendedData-6                  0000000209D6unused entry in sub-node-table  000000001000snTEDaTa00000002018CØ       dEnDDaTa000000020220
+                                                             dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000002031ATaiLDaTa0000000203AA!   "   #   $   %   &   '   (   )   *   +   ,   -   .   /   0   1   2   3   4   5   6   7   8   9   :   ;   <   =   >   ?   @   dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000204A4TaiLDaTa000000020534A   B   C   D   E   F   G   H   I   J   K   L   M   N   O   P   Q   R   S   T   U   V   W   X   Y   Z   [   \   ]   ^   _   `   dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4
                        01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000002062ETaiLDaTa0000000206BEa   b   c   d   e   f   g   h   i   j   k   l   m   n   o   p   q   r   s   t   u   v   w   x   y   z   {   |   }   ~         dEnDNoDeExtendedData-4                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000207B8TaiLDaTa000000020848
        dEnDNoDeExtendedData-5                  extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000020942TaiLDaTa0000000209D2¡   ¢   £   ¤   ¥   ¦   §   ¨   ©   ª   «
 ¬      ®   ¯   °   ±   ²   ³   ´   µ   ¶   ·   ¸   ¹   º   »   ¼   ½   ¾   ¿   À   dEnDNoDeExtendedData-6                  extendedData                    0000000000000000000000001000I4                              010000001800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000020ACCTaiLDaTa000000020B3CÁ   Â   Ã   Ä   Å   Æ   Ç   È   É   Ê   Ë   Ì   Í   Î   Ï   Ð   Ñ   Ò   Ó   Ô   Õ   Ö   ×   Ø   dEnDNoDeDimension                       Dimension                       0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000020DAATaiLSNTb000000020DA6Dimension                       000000020B40ScaleFactor                     000000020DC2MapId                           000000020ED0Coordinates                     000000030000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry
 in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000020DBE   dEnDNoDeScaleFactor                     ScaleFactor                     0000000000000000000000001000R4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000020EB8TaiLDaTa000000020ECC  ?dEnDNoDeMapId                           MapId                           0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000020FC6TaiLDaTa000000020FDA   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeCoordinates                     Coordinates                     0000002C0000003C000000080278R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030384TaiLNoDeExtendedSize                    extendedData
   0000000000000000000000001000I8                              010000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030360TaiLFreE00000003035C000000000EB7xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa000000030380       Ø       dEnDDaTa00000003040C                                      ð?                       @                      @                      @        dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030506TaiLDaTa00000003058
 E              @              ð?                      ð?      ð?              ð?       @              ð?      @        dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030688TaiLDaTa000000030710      ð?      @              ð?      @               @                       @      ð?               @       @        dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000R8                              02000000030000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000100000003080ATaiLDaTa000000030892       @      @               @      @               @      @              @                      @      ð?        dEnDNoDeExtendedData-4                  extendedData                    000000000000000000000000
 1000R8                              02000000030000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000100000003098CTaiLDaTa000000030A14      @       @              @      @              @      @              @      @              @                dEnDNoDeExtendedData-5                  extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030B0ETaiLDaTa000000030B96      @      ð?              @       @              @      @              @      @              @      @        dEnDNoDeExtendedData-6                  extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030C90TaiLDaTa000000030D18      @                      @      ð?
        @       @              @      @              @      @        dEnDNoDeExtendedData-7                  extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000030E12TaiLDaTa000000030E9A      @      @                              ð?              ð?      ð?               @      ð?              @      ð?dEnDNoDeExtendedData-8                  extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000040224TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzFreE0000000402200000000301ECxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000000402AC              @      ð?              @      ð?      ð?              ð?      ð?      ð?      ð?      ð?       @      ð?dEnDNoDeExtendedData-9                  extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000403A6TaiLDaTa00000004042E      ð?      @      ð?      ð?      @      ð?      ð?      @      ð?       @              ð?       @      ð?      ð?dEnDNoDeExtendedData-10                 extendedData                    0000000000000000000
 000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000040528TaiLDaTa0000000405B0       @       @      ð?       @      @      ð?       @      @      ð?       @      @      ð?      @              ð?dEnDNoDeExtendedData-11                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000406AATaiLDaTa000000040732      @      ð?      ð?      @       @      ð?      @      @      ð?      @      @      ð?      @      @      ð?dEnDNoDeExtendedData-12                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000040B58TaiLFreE000000040B54000000040000xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa000000040BE0      @              ð?      @      ð?      ð?      @       @      ð?      @      @      ð?      @      @      ð?dEnDNoDeExtendedData-13                 extendedData                    000000000000000000000000100
 0R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000040CDATaiLDaTa000000040D62      @      @      ð?      @              ð?      @      ð?      ð?      @       @      ð?      @      @      ð?dEnDNoDeExtendedData-14                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000040E5CTaiLDaTa000000040EE4      @      @      ð?      @      @      ð?                       @              ð?       @               @       @dEnDNoDeExtendedData-15                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050000TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzDaTa000000050088              @
        @              @       @              @       @      ð?               @      ð?      ð?       @dEnDNoDeExtendedData-16                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050182TaiLDaTa00000005020A      ð?       @       @      ð?      @       @      ð?      @       @      ð?      @       @       @               @dEnDNoDeExtendedData-17                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050304TaiLDaTa00000005038C       @      ð?       @       @       @       @       @      @       @       @      @       @       @      @       @dEnDNoDeExtendedData-18                 extendedData                    0000000000000000000000001000R8
                    02000000030000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000100000005093ETaiLFreE00000005093A000000001000xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000000509C6      @               @      @      ð?       @      @       @       @      @      @       @      @      @       @dEnDNoDeExtendedData-19                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050AC0TaiLDaTa000000050B48      @      @       @      @               @      @      ð?       @      @       @       @      @      @       @dEnDNoDeExtendedData-20                 extendedData                    0000000000000000000000001000R8
                      020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050C42TaiLDaTa000000050CCA      @      @       @      @      @       @      @               @      @      ð?       @      @       @       @dEnDNoDeExtendedData-21                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050DC4TaiLDaTa000000050E4C      @      @       @      @      @       @      @      @       @                      @              ð?      @dEnDNoDeExtendedData-22                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000050F46TaiLDaTa000000050FCE               @      @              @      @
 @      @              @      @      ð?              @dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-23                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000600F6TaiLDaTa00000006017E      ð?      ð?      @      ð?       @      @      ð?      @      @      ð?      @      @      ð?      @      @dEnDNoDeExtendedData-24                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000060278TaiLDaTa000000060300       @              @       @      ð?      @       @       @      @       @      @      @       @      @      @dEnDNoDeExtendedData-25                 extendedData                    0000000000000000000000001000R8
                    0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000603FATaiLDaTa000000060482       @      @      @      @              @      @      ð?      @      @       @      @      @      @      @dEnDNoDeExtendedData-26                 extendedData                    0000000000000000000000001000R8                              02000000030000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000100000006057CTaiLDaTa000000060604      @      @      @      @      @      @      @              @      @      ð?      @      @       @      @dEnDNoDeExtendedData-27                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000060DF2TaiLFreE000000060DEE000000050486xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa000000060E7A      @      @      @      @      @      @      @      @      @      @              @      @      ð?      @dEnDNoDeExtendedData-28                 extendedData                    0000000000000000000000001000R8                              0200000003
 00000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000060F74TaiLDaTa000000060FFC      @       @      @      @      @      @      @      @      @      @      @      @                      @dEnDNoDeExtendedData-29                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000700F6TaiLDaTa00000007017E              ð?      @               @      @              @      @              @      @              @      @dEnDNoDeExtendedData-30                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000070278TaiLDaTa000000070300      ð?              @      ð?      ð?      @      ð?       @      @      ð?      @
  @      ð?      @      @dEnDNoDeExtendedData-31                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000703FATaiLDaTa000000070482      ð?      @      @       @              @       @      ð?      @       @       @      @       @      @      @dEnDNoDeExtendedData-32                 extendedData                    0000000000000000000000001000R8                              02000000030000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000100000007057CTaiLDaTa000000070604       @      @      @       @      @      @      @              @      @      ð?      @      @       @      @dEnDNoDeExtendedData-33                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000
 000000000000000000000000000000000000000000010000000706FETaiLDaTa000000070786      @      @      @      @      @      @      @      @      @      @              @      @      ð?      @dEnDNoDeExtendedData-34                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000070880TaiLDaTa000000070908      @       @      @      @      @      @      @      @      @      @      @      @      @              @dEnDNoDeExtendedData-35                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000070A02TaiLDaTa000000070A8A      @      ð?      @      @       @      @      @      @      @      @      @      @      @      @      @dEnDNoDeExtendedData-
 36                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000070B84TaiLDaTa000000070C0C                      @              ð?      @               @      @              @      @              @      @dEnDNoDeExtendedData-37                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000070D06TaiLDaTa000000070D8E              @      @      ð?              @      ð?      ð?      @      ð?       @      @      ð?      @      @dEnDNoDeExtendedData-38                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000
 00070E88TaiLDaTa000000070F10      ð?      @      @      ð?      @      @       @              @       @      ð?      @       @       @      @dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-39                 extendedData                    0000000000000000000000001000R8                              0200000003000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000800F6TaiLDaTa00000008017E       @      @      @       @      @      @       @      @      @      @              @      @      ð?      @dEnDNoDeExtendedData-40                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000
 000000000000001000000080CDCTaiLSNTb000000080CD8ExtendedSize                    0000000300F6ExtendedData-1                  000000030410ExtendedData-2                  000000030592ExtendedData-3                  000000030714ExtendedData-4                  000000030896ExtendedData-5                  000000030A18ExtendedData-6                  000000030B9AExtendedData-7                  000000030D1CExtendedData-8                  000000030E9EExtendedData-9                  0000000402B0ExtendedData-10                 000000040432ExtendedData-11                 0000000405B4ExtendedData-12                 000000040736ExtendedData-13                 000000040BE4ExtendedData-14                 000000040D66ExtendedData-15                 000000040EE8ExtendedData-16                 00000005008CExtendedData-17                 00000005020EExtendedData-18                 000000050390ExtendedData-19                 0000000509CAExtendedData-20                 000000050B4CExtendedData-21
               000000050CCEExtendedData-22                 000000050E50ExtendedData-23                 000000060000ExtendedData-24                 000000060182ExtendedData-25                 000000060304ExtendedData-26                 000000060486ExtendedData-27                 000000060608ExtendedData-28                 000000060E7EExtendedData-29                 000000070000ExtendedData-30                 000000070182ExtendedData-31                 000000070304ExtendedData-32                 000000070486ExtendedData-33                 000000070608ExtendedData-34                 00000007078AExtendedData-35                 00000007090CExtendedData-36                 000000070A8EExtendedData-37                 000000070C10ExtendedData-38                 000000070D92ExtendedData-39                 000000080000ExtendedData-40                 000000080182ExtendedData-41                 000000080D68ExtendedData-42                 000000080EEAExtendedData-43                 0000000
 9008Cunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000080D64      @       @      @      @      @      @      @      @      @      @      @      @      @              @dEnDNoDeExtendedData-41                 extendedData                    0000000000000000000000001000R8                              02000000
 0300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000080E5ETaiLDaTa000000080EE6      @      ð?      @      @       @      @      @      @      @      @      @      @      @      @      @dEnDNoDeExtendedData-42                 extendedData                    0000000000000000000000001000R8                              020000000300000005000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000090000TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzDaTa000000090088      @              @      @      ð?      @      @       @      @      @      @      @      @      @      @dEnDNoDeExtendedData-43                 extendedData                    0000000000000000000000001000R8                              020000000300000001000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000090182TaiLDaTa0000000901AA      @      @      @dEnDNoDeCells
      cells                           00000004000000080000000A0274MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb000000090414Cells                           0000000901AEInternalFaces                   0000000B06B6BoundaryFaces-0                 0000001A052CNumBoundaryTypes                0000001A0622BoundaryFaces-1                 0000001E0A66BoundaryFaces-2                 000000200558unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeMap-2                           map                             0000000300000008000000090604MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeLabel                           Label                           0000000000000000000000001000C1                              0100000008000000000000000000
 00000000000000000000000000000000000000000000000000000000000000000000000001000000090778TaiLSNTb000000090774Label                           00000009050EMaximumMappedId                 000000090794IdMap                           0000000908A2unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000090790Cell mapdEnDNoDeMaximumMappedId                 MaximumMappedId                 0000000000000000000000001000I4                              01000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000009088ATaiLDaTa00000009089E}   dEnDNoDeIdMap                           IdMap                           0000000400000008000000090A8EI4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 1000000090C1ETaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000090C02TaiLSNTb000000090BFEExtendedSize                    000000090998ExtendedData-1                  000000090CB2ExtendedData-2                  000000090E3CExtendedData-3                  0000000A0000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000090C1A}       dEnDDaTa000000090CAE
+                                                             dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000090DA8TaiLDaTa000000090E38!   "   #   $   %   &   '   (   )   *   +   ,   -   .   /   0   1   2   3   4   5   6   7   8   9   :   ;   <   =   >   ?   @   dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000090F32TaiLDaTa000000090FC2A   B   C   D   E   F   G   H   I   J   K   L   M   N   O   P   Q   R   S   T   U   V   W   X   Y   Z   [   \   ]   ^   _   `   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-3                  extendedDat
 a                    0000000000000000000000001000I4                              010000001D000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A00F6TaiLDaTa0000000A017Aa   b   c   d   e   f   g   h   i   j   k   l   m   n   o   p   q   r   s   t   u   v   w   x   y   z   {   |   }   dEnDNoDeNumCells                        NumCells                        0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A03E8TaiLSNTb0000000A03E4NumCells                        0000000A017EMapId                           0000000A0400CellType                        0000000A050ECellTopologyType                0000000A0DB0unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000A03FC}   dEnDNoDeMapId
                         MapId                           0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A04F6TaiLDaTa0000000A050A   dEnDNoDeCellType                        CellType                        00000004000000080000000A06FAI4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A088ATaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A086ETaiLSNTb0000000A086AExtendedSize                    0000000A0604ExtendedData-1                  0000000A091EExtendedData-2                  0000000A0AA8ExtendedData-3                  0000000A0C32unused entry in sub-node-table  000000001000unu
 sed entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000A0886}       dEnDDaTa0000000A091A        dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A0A14TaiLDaTa0000000A0AA4        dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A0B9ETaiLDaTa0000000A0C2E
        dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              010000001D000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000A0D28TaiLDaTa0000000A0DAC        dEnDNoDeCellTopologyType                CellTopologyType                00000004000000080000000B0000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B0190TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B0174TaiLzzzzzzz
 zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzSNTb0000000B0170ExtendedSize                    0000000A0EA6ExtendedData-1                  0000000B0224ExtendedData-2                  0000000B03AEExtendedData-3                  0000000B0538unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000B018C}       dEnDDaTa0000000B0220        dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B031ATaiLDaTa0000000B03AA
                                 dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B04A4TaiLDaTa0000000B0534        dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              010000001D000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B062ETaiLDaTa0000000B06B2        dEnDNoDeInternalFaces                   internalFaces                   00000005000000080000000D013AMT                              000000000000000000000000000000000000000
 000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeMap-3                           map                             00000003000000080000000B0998MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeLabel                           Label                           0000000000000000000000001000C1                              0100000008000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B0B0CTaiLSNTb0000000B0B08Label                           0000000B08A2MaximumMappedId                 0000000B0B28IdMap                           0000000B0C36unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000B0B24Face mapdEnDNoDeMaximumMappedI
 d                 MaximumMappedId                 0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B0C1ETaiLDaTa0000000B0C32  dEnDNoDeIdMap                           IdMap                           0000000A0000000C0000000C0C50I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C0000TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000B0F96TaiLFreE0000000B0F9200000004082Cxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000000B0FAE,      dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzDaTa0000000C0090                  "   $   &   '   )   +   ,   .   /   2   4   5   6   7   8   9   :   ;   =   ?   @   A   B   C   D   E   dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C018ATaiLDaTa0000000C021AF   G   H   I   J   K   M   O   P   Q   R   S   T   U   V   X   Y   [   _   a   b   d   f   j   k   m   n   o   p   q   r   s   dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000
 00000000000000010000000C0314TaiLDaTa0000000C03A4t   u   w   y   z   {   |   }   ~
                                                   dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C049ETaiLDaTa0000000C052E                      ¢   ¤   ¥   ¦   §   ¨   ©   ª   «      ®   °   ´   ¶   ·   ¹   »   ¿   À   Â   Ã   Ä   Å   Æ   Ç   dEnDNoDeExtendedData-4                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C0628TaiLDaTa0000000C06B8È   É   Ê   Ì   Î   Ï   Ð   Ñ   Ò   Ó   Ô   Õ   Ö   ×   Ø   Ù   Ú   Ü   Þ   ß   à   á   â   ã   ä   å   ç   é   ê   ë   ì   í   dEnDNoDeExtendedData-5
                extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C07B2TaiLDaTa0000000C0842î   ï   ð   ñ   ò   ó   ô   õ   ÷   ù   ú   û   ü   ý   þ   ÿ            	                        dEnDNoDeExtendedData-6                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C093CTaiLDaTa0000000C09CC        !  #  $  %  &  '  (  )  *  +  ,  -  .  /  1  3  4  5  6  7  8  9  :  <  >  ?  @  A  dEnDNoDeExtendedData-7                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 000000010000000C0AC6TaiLDaTa0000000C0B56B  C  D  E  F  G  H  I  J  L  N  O  P  Q  R  S  T  U  W  X  Z  ^  `  a  c  e  i  j  l  m  n  o  dEnDNoDeExtendedData-8                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000C0E74TaiLSNTb0000000C0E70ExtendedSize                    0000000B0D2CExtendedData-1                  0000000C0094ExtendedData-2                  0000000C021EExtendedData-3                  0000000C03A8ExtendedData-4                  0000000C0532ExtendedData-5                  0000000C06BCExtendedData-6                  0000000C0846ExtendedData-7                  0000000C09D0ExtendedData-8                  0000000C0B5AExtendedData-9                  0000000C0F08unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000C0F04p  q
  r  s  t  v  x  y  z  {  |  }  ~                                        dEnDNoDeExtendedData-9                  extendedData                    0000000000000000000000001000I4                              010000000C000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D0000TaiLzzDaTa0000000D0040          ¡  £  ¥  ¦  ¨  ª    dEnDNoDeNumFaces                        NumFaces                        0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D02AETaiLSNTb0000000D02AANumFaces                        0000000D0044MapId                           0000000D02C6Vertices                        0000000D03D4Cells                           00000014048EProstarFaceId                   00000017052Cunused entry in sub-node-table  000000001000unused entry in sub-no
 de-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000000D02C2,  dEnDNoDeMapId                           MapId                           0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D03BCTaiLDaTa0000000D03D0   dEnDNoDeVertices                        Vertices                        0000002F0000003C000000130000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D0750TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D0734TaiLFreE0000000D07300000000B0E22xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000000D074CÜ      dEnDDaTa0000000D07E0         ,   &         	   -   '
+   .   (            ,   +            /   )         	   -   ,      	   dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D08DATaiLDaTa0000000D096A
+      /   .            2   ,            0   /      	      3   -
+      4   .
+      2   dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D0A64TaiLDaTa0000000D0AF41            5   /            3   2            4   3            5   4            8   2            6   5      dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D0BEETaiLDaTa0000000D0C7E      9   3            :   4            8   7            ;   5            9   8            :   9            dEnDNoDeExtendedData-4                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000
 000000000000000000000000000000000000000000000000000000000000000010000000D0D78TaiLDaTa0000000D0E08;   :      %   &   ,   +            >   8            <   ;      &   '   -   ,            ?   9      '   (   .   -   dEnDNoDeExtendedData-5                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000D0F02TaiLDaTa0000000D0F92         @   :            >   =      (   )   /   .            A   ;            ?   >      )   *   0   /         dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-6                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000E00F6TaiLDaTa0000000E01
 86   @   ?            A   @      +   ,   2   1             D   >            B   A      ,   -   3   2         !   E   dEnDNoDeExtendedData-7                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000E0280TaiLDaTa0000000E0310?      -   .   4   3         "   F   @      .   /   5   4         #   G   A      /   0   6   5      1   2   8   7      dEnDNoDeExtendedData-8                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000E062ETaiLFreE0000000E062A0000000D05C0xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000000E06BE2   3   9   8      3   4   :   9      4   5   ;   :      5   6   <   ;      7   8   >   =      &   ,   P   J      8   9   dEnDNoDeExtendedData-9                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000E07B8TaiLDaTa0000000E0848?   >      '   -   Q   K      9   :   @   ?      (   .   R   L      +   ,   P   O      :   ;   A   @      )   /   S   M   dEnDNoDeExtendedData-10                 extendedData                    0000000000000000000000001000I4
               0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000E0942TaiLDaTa0000000E09D2   ,   -   Q   P      ;   <   B   A      -   .   R   Q      .   /   S   R      =   >   D   C      ,   2   V   P      /   dEnDNoDeExtendedData-11                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000E0ACCTaiLDaTa0000000E0B5C0   T   S      >   ?   E   D      -   3   W   Q      ?   @   F   E      .   4   X   R      1   2   V   U      @   A   G   dEnDNoDeExtendedData-12                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000F0000TaiLFreE0000000E0F7E0000000E040Axxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzDaTa0000000F0090F      /   5   Y   S      2   3   W   V      A   B   H   G      3   4   X   W      4   5   Y   X
    2   8   \   V      dEnDNoDeExtendedData-13                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000F018ATaiLDaTa0000000F021A5   6   Z   Y      3   9   ]   W      4   :   ^   X      7   8   \   [      5   ;   _   Y      8   9   ]   \      9   :   dEnDNoDeExtendedData-14                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000F0314TaiLDaTa0000000F03A4^   ]      :   ;   _   ^      I   J   P   O      8   >   b   \      ;   <   `   _      J   K   Q   P      9   ?   c   ]   dEnDNoDeExtendedData-15                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000
 0000000000000000000000000000000000000000000000000000000010000000F049ETaiLDaTa0000000F052E   K   L   R   Q      :   @   d   ^      =   >   b   a      L   M   S   R      ;   A   e   _      >   ?   c   b      M   dEnDNoDeExtendedData-16                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000F0628TaiLDaTa0000000F06B8N   T   S      ?   @   d   c      @   A   e   d      O   P   V   U      >   D   h   b      A   B   f   e      P   Q   W   dEnDNoDeExtendedData-17                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000F07B2TaiLDaTa0000000F0842V      ?   E   i   c      Q   R   X   W      @   F   j   d      R   S   Y   X      A   G   k   e      S
 T   Z   Y      dEnDNoDeExtendedData-18                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000F0DF4TaiLFreE0000000F0DF00000000606FExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000000F0E84U   V   \   [      V   W   ]   \      W   X   ^   ]      X   Y   _   ^      Y   Z   `   _      [   \   b   a      J   P   dEnDNoDeExtendedData-19                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000100000TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
 zzzzzzzzzzzzzzzzzzzzDaTa000000100090t   n      \   ]   c   b      K   Q   u   o      ]   ^   d   c      L   R   v   p      O   P   t   s      ^   _   e   d   dEnDNoDeExtendedData-20                 extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000010018ATaiLDaTa00000010021A   M   S   w   q      P   Q   u   t      _   `   f   e      Q   R   v   u      R   S   w   v      a   b   h   g      P   dEnDNoDeExtendedData-21                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000100314TaiLDaTa0000001003A4V   z   t      S   T   x   w      b   c   i   h      Q   W   {   u      c   d   j   i      R   X   |   v      U   V   z   dEnDNoDeExtendedData-22
    extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000010049ETaiLDaTa00000010052Ey      d   e   k   j      S   Y   }   w      V   W   {   z      e   f   l   k      W   X   |   {      X   Y   }   |      dEnDNoDeExtendedData-23                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000100628TaiLDaTa0000001006B8V   \      z      Y   Z   ~   }      W   ]      {      X   ^      |      [   \            Y   _      }      \   ]   dEnDNoDeExtendedData-24                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000
 001007B2TaiLDaTa000000100842         ]   ^            ^   _            m   n   t   s      \   b            _   `            n   o   u   t   dEnDNoDeExtendedData-25                 extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000010093CTaiLDaTa0000001009CC   ]   c            o   p   v   u      ^   d            a   b
      p   q   w   v      _   e            b   dEnDNoDeExtendedData-26                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000100AC6TaiLDaTa000000100B56c            q   r   x   w      c   d            d   e            s   t   z   y      b   h            e   f      dEnDNoDeExtendedData-27                 exten
 dedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001106F4TaiLFreE000000100FFC0000000E0C56xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCFreE0000001106F00000000F093Cxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa000000110784      t   u   {   z
      c   i            u   v   |   {      d   j            v   w   }   |      e   k            dEnDNoDeExtendedData-28                 extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000011087ETaiLDaTa00000011090Ew   x   ~   }      y   z            z   {            {   |            |   }            }   ~                  dEnDNoDeExtendedData-29                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000110A08TaiLDaTa000000110A98
      n   t                           o   u                           p   v            s   t         dEnDNoDeExtendedData-30                 extendedData                    00000000000000000000000
 01000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000110B92TaiLDaTa000000110C22                  q   w            t   u                           u   v            v   w
   dEnDNoDeExtendedData-31                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000110D1CTaiLDaTa000000110DAC            t   z            w   x                           u   {                           v   |       dEnDNoDeExtendedData-32                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000110EA6TaiLDaTa000000110F36      y   z
               w   }   ¡         z   {                           {   |             dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-33                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001200F6TaiLDaTa000000120186|   }   ¡          z      ¤         }   ~   ¢   ¡      {      ¥         |      ¦                ¤   £      }      dEnDNoDeExtendedData-34                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000120280TaiLDaTa000000120310§   ¡            ¥   ¤
       ¦   ¥            §   ¦                           ª   ¤            ¨   §   dEnDNoDeExtendedData-35                 extendedData                    0000000000000000000000001000I4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000012040ATaiLDaTa00000012049A                        «   ¥                           ¬   ¦
      ª   ©                        dEnDNoDeExtendedData-36                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000120594TaiLDaTa000000120624      §            «   ª                           ¬   «               ¬                           °   dEnDNoDeExtendedData-37                 extendedData                    0000000000000000000000001000I4
                           01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000012071ETaiLDaTa0000001207AEª            ®                              ±   «                            ²   ¬            ¡          dEnDNoDeExtendedData-38                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001208A8TaiLDaTa000000120938      ³               ¢   ¡            ¤   £            ¥   ¤             ¦   ¥          ¡   §   ¦      ¡   ¢   dEnDNoDeExtendedData-39                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000120A32TaiLDaTa000000120AC2¨   §      £   ¤   ª   ©            ¼
    ¶      ¤   ¥   «   ª            ½   ·      ¥   ¦   ¬   «            ¾   ¸   dEnDNoDeExtendedData-40                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000130A64TaiLFreE000000120FFC000000110000xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCSNTb000000130A60ExtendedSize                    0000000D04CAExtendedData-1                  0000000D07E4ExtendedData-2                  0000000D096EExtendedData-3                  0000000D0AF8ExtendedData-4                  0000000D0C82ExtendedData-5                  0000000D0E0CExtendedData-6                  0000000E0000ExtendedData-7                  0000000E018AExtendedData-8                  0000000E0314ExtendedData-9                  0000000E06C2ExtendedData-10                 0000000E084CExtendedData-11                 0000000E09D6Exten
 dedData-12                 0000000E0B60ExtendedData-13                 0000000F0094ExtendedData-14                 0000000F021EExtendedData-15                 0000000F03A8ExtendedData-16                 0000000F0532ExtendedData-17                 0000000F06BCExtendedData-18                 0000000F0846ExtendedData-19                 0000000F0E88ExtendedData-20                 000000100094ExtendedData-21                 00000010021EExtendedData-22                 0000001003A8ExtendedData-23                 000000100532ExtendedData-24                 0000001006BCExtendedData-25                 000000100846ExtendedData-26                 0000001009D0ExtendedData-27                 000000100B5AExtendedData-28                 000000110788ExtendedData-29                 000000110912ExtendedData-30                 000000110A9CExtendedData-31                 000000110C26ExtendedData-32                 000000110DB0ExtendedData-33                 000000120000ExtendedData-34
       00000012018AExtendedData-35                 000000120314ExtendedData-36                 00000012049EExtendedData-37                 000000120628ExtendedData-38                 0000001207B2ExtendedData-39                 00000012093CExtendedData-40                 000000120AC6ExtendedData-41                 000000130AF8ExtendedData-42                 000000130C82ExtendedData-43                 000000130E0CExtendedData-44                 000000140000ExtendedData-45                 00000014018AExtendedData-46                 000000140314unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unu
 sed entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000130AF4         ¼   »      ¦   §      ¬            ¿   ¹            ½   ¼      §   ¨   ®               ¾   ½         dEnDNoDeExtendedData-41                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000130BEETaiLDaTa000000130C7E   ¿   ¾      ©   ª   °   ¯            Â   ¼            À   ¿      ª   «   ±   °            Ã   ½      «   ¬   ²   dEnDNoDeExtendedData-42                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000130D78TaiLDaTa000000130E08±             Ä   ¾            Â   Á      ¬
    ³   ²         ¡   Å   ¿            Ã   Â         ®   ´   ³      dEnDNoDeExtendedData-43                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000130F02TaiLDaTa000000130F92       Ä   Ã          ¡   Å   Ä         ¤   È   Â      ¡   ¢   Æ   Å         ¥   É   Ã          ¦   Ê   Ä      £   ¤   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-44                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001400F6TaiLDaTa000000140186È   Ç      ¡   §   Ë   Å      ¤   ¥   É   È      ¥   ¦   Ê   É      ¦   §   Ë   Ê      ¤   ª   Î   È      §   ¨   Ì   Ë   dEnDNoDeExtendedDat
 a-45                 extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000140280TaiLDaTa000000140310   ¥   «   Ï   É      ¦   ¬   Ð   Ê      ©   ª   Î   Í      §      Ñ   Ë      ª   «   Ï   Î      «   ¬   Ð   Ï      ¬   dEnDNoDeExtendedData-46                 extendedData                    0000000000000000000000001000I4                              010000001C0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000014040ATaiLDaTa00000014048A   Ñ   Ð      ª   °   Ô   Î         ®   Ò   Ñ      «   ±   Õ   Ï      ¬   ²   Ö   Ð         ³   ×   Ñ   dEnDNoDeCells                           Cells                           000000130000001B000000170000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100
 0000140812TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001407EETaiLFreE0000001407EA000000100C50xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa00000014080E       ,      dEnDDaTa0000001408A2
+   dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000014099CTaiLDaTa000000140A2C
+                                                dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000140B26TaiLDaTa000000140BB6        !            "   	   dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000140CB0TaiLDaTa000000140D40      #
+   '      (      )            *            +                  ,            dEnDNoDeExtendedData-4                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000140E3ATaiLDaTa000000140ECA       -         !      "   .                #   /      !       0      "   !      $   1      #   "       %   2      dEnDNoDeExtendedData-5                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000150000TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzDaTa000000150090!   &   "   '   %   $   #   (   &   %   '   &   $   )   (   '   %   *   &   +   '   ,   3      *   )   (   -   4      +   *   dEnDNoDeExtendedData-6
                extendedData                    0000000000000000000000001000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000015018ATaiLDaTa00000015021A5      ,   +   )   .   6      -   ,   *   /   7      +   0   ,   1   8      /   .   -   2   9       0   /   :   !   1   0   dEnDNoDeExtendedData-7                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000150314TaiLDaTa0000001503A4;   "   2   1   <   #   =   $   >   %   ?   &   @   '   A   (   B   )   4   3   C   *   5   4   D   +   6   5   3   8   E   ,   dEnDNoDeExtendedData-8                  extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000
 000000010000001506C2TaiLFreE0000001506BE00000014067AxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000001507527   6   4   9   F   -   5   :   6   ;   G   .   9   8   7   <   H   /   :   9   I   0   ;   :   8   =   J   1   <   ;   9   >   dEnDNoDeExtendedData-9                  extendedData                    0000000000000000000000001000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000015084CTaiLDaTa0000001508DCK   2
  :   ?   ;   @   >   =   <   A   ?   >   @   ?   =   B   A   @   >   C   ?   D   @   E   L   3   C   B   A   F   M   4   dEnDNoDeExtendedData-10                 extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001509D6TaiLDaTa000000150A66D   C   N   5   E   D   B   G   O   6   F   E   C   H   P   7   D   I   E   J   Q   8   H   G   F   K   R   9   I   H   S   :   dEnDNoDeExtendedData-11                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000150B60TaiLDaTa000000150BF0J   I   T   ;   K   J   U   <   V   =   W   >   X   ?   Y   @   Z   A   [   B   M   L   \   C   N   M   ]   D   O   N   L   Q   dEnDNoDeExtendedData-12                 extendedData                    00000000
 00000000000000001000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000016032CTaiLFreE000000150FFC00000015049ExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCFreE000000160328000000150CEAx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000001603BC^   E   P   O   M   R   _   F   N   S   O   T   `   G   R   Q   P   U   a   H   S   R   b   I   T   S   Q   V   c   J   U   T   dEnDNoDeExtendedData-13                 extendedData
           0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001604B6TaiLDaTa000000160546R   W   d   K   S   X   T   Y   W   V   U   Z   X   W   Y   X   V   [   Z   Y   W   \   X   ]   Y   ^   e   L   \   [   Z   _   dEnDNoDeExtendedData-14                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000160640TaiLDaTa0000001606D0f   M   ]   \   g   N   ^   ]   [   `   h   O   _   ^   \   a   i   P   ]   b   ^   c   j   Q   a   `   _   d   k   R   b   a   dEnDNoDeExtendedData-15                 extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001607CATaiLDaTa000000160
 85Al   S   c   b   m   T   d   c   n   U   o   V   p   W   q   X   r   Y   s   Z   t   [   f   e   u   \   g   f   v   ]   h   g   dEnDNoDeExtendedData-16                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000160954TaiLDaTa0000001609E4e   j   w   ^   i   h   f   k   x   _   g   l   h   m   y   `   k   j   i   n   z   a   l   k   {   b   m   l   j   o   |   c   dEnDNoDeExtendedData-17                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000160ADETaiLDaTa000000160B6En   m   k   p   }   d   l   q   m   r   p   o   n   s   q   p   r   q   o   t   s   r   p   u   q   v   r   w   u   t   s   x   dEnDNoDeExtendedData-18                 extendedData
   0000000000000000000000001000I4                              02000000020000000C0000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001704B8TaiLFreE000000160FFC000000160000xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCSNTb0000001704B4ExtendedSize                    000000140584ExtendedData-1                  0000001408A6ExtendedData-2                  000000140A30ExtendedData-3                  000000140BBAExtendedData-4                  000000140D44ExtendedData-5                  000000140ECEExtendedData-6                  000000150094ExtendedData-7                  00000015021EExtendedData-8                  0000001503A8ExtendedData-9                  000000150756ExtendedData-10                 0000001508E0ExtendedData-11                 000000150A6AExtendedData-12                 000000150BF4ExtendedData-13                 0000001603C0ExtendedData-14                 00000016054AExtendedData-15                 0000001606D4ExtendedData-16                 00000016085EExtendedData-17                 0000001609E8ExtendedData-18                 000000160B72unused entry in sub-node-t
 able  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000170528v   u   w   v   t   y   x   w   u   z   v   {   w   |   z   y   x   }   {   z   |   {   }   |   dEnDNoDeProstarFaceId                   ProstarFaceId                   000000130000001B0000001A0000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001708B0TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              01000000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000017088CTaiLFreE000000170888000000160C68xxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000001708AC       ,      dEnDDaTa000000170940        dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000170A3ATaiLDaTa000000170ACA        dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000
 001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000170BC4TaiLDaTa000000170C54        dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000170D4ETaiLDaTa000000170DDE        dEnDNoDeExtendedData-4                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000170ED8TaiLDaTa000000170F68
        dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-5                  extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001800F6TaiLDaTa000000180186        dEnDNoDeExtendedData-6                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000180280TaiLDaTa000000180310
                                    dEnDNoDeExtendedData-7                  extendedData                    0000000000000000000000001000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000018040ATaiLDaTa00000018049A        dEnDNoDeExtendedData-8                  extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001807B8TaiLFreE0000001807B4000000170718xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa000000180848        dEnDNoDeExtendedData-9                  extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000180942TaiLDaTa0000001809D2        dEnDNoDeExtendedData-10                 extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000
 00000000000000000000000000000001000000180ACCTaiLDaTa000000180B5C        dEnDNoDeExtendedData-11                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000180C56TaiLDaTa000000180CE6        dEnDNoDeExtendedData-12                 extendedData                    0000000000000000000000001000I4                              02000000020000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000019032CTaiLFreE000000180FFC000000180594xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCFreE000000190328000000180DE0xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000001903BC        dEnDNoDeExtendedData-13                 extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001904B6TaiLDaTa000000190546        dEnDNoDeExtendedData-14                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000
 000190640TaiLDaTa0000001906D0        dEnDNoDeExtendedData-15                 extendedData                    0000000000000000000000001000I4                              0200000002000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001907CATaiLDaTa00000019085A        dEnDNoDeExtendedData-16                 extendedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000190954TaiLDaTa0000001909E4        dEnDNoDeExtendedData-17                 exte
 ndedData                    0000000000000000000000001000I4                              020000000200000010000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000190ADETaiLDaTa000000190B6E        dEnDNoDeExtendedData-18                 extendedData                    0000000000000000000000001000I4                              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
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCSNTb0000001A04B4ExtendedSize                    000000170622ExtendedData-1                  000000170944ExtendedData-2                  000000170ACEExtendedData-3                  000000170C58ExtendedData-4                  000000170DE2ExtendedData-5                  000000180000ExtendedData-6                  00000018018AExtendedData-7                  000000180314ExtendedData-8                  00000018049EExtendedData-9                  00000018084CEx
 tendedData-10                 0000001809D6ExtendedData-11                 000000180B60ExtendedData-12                 000000180CEAExtendedData-13                 0000001903C0ExtendedData-14                 00000019054AExtendedData-15                 0000001906D4ExtendedData-16                 00000019085EExtendedData-17                 0000001909E8ExtendedData-18                 000000190B72unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001A0528        dEnDNoDeBoundaryFaces-0                 boundaryFaces                   00000006000000080000001B0524MT
      000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeNumBoundaryTypes                NumBoundaryTypes                0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001A0718TaiLDaTa0000001A072C   dEnDNoDeMap-4                           map                             00000003000000080000001A091CMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeLabel                           Label                           0000000000000000000000001000C1                              0100000008000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001A0A90TaiLSNTb0000001A0A8CLabel                           0000001A0826MaximumMappedId                 0000001A0AAC
 IdMap                           0000001A0BBAunused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001A0AA8Face mapdEnDNoDeMaximumMappedId                 MaximumMappedId                 0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001A0BA2TaiLDaTa0000001A0BB6Â  dEnDNoDeIdMap                           IdMap                           00000004000000080000001A0DA6I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001A0F36TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000
 000000000000000000000000000000000000000000000000000010000001A0F1ATaiLSNTb0000001A0F16ExtendedSize                    0000001A0CB0ExtendedData-1                  0000001B0000ExtendedData-2                  0000001B018AExtendedData-3                  0000001B0314unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001A0F32d       dEnDDaTa0000001A0FC6
+                            !   #   %   (   *   -   0   1   3   <   >   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B00F6TaiLDaTa0000001B0186L   N   \   h   v   x               ¡   £   ±   ½   Ë   Í   Û   Ý   æ   è   ö   ø          "  0  2  ;  =  K  M  dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B0280TaiLDaTa0000001B0310[  g  u  w
                     ¢  ¤  §  ©  ¬  ¯  °  ³  µ  ¶  ·  ¸  ¹  º  »  ¼  ½  ¾  dEnDNoDeExtendedData-3                  extendedData
                  0000000000000000000000001000I4                              0100000004000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B040ATaiLDaTa0000001B042A¿  À  Á  Â  dEnDNoDeNumFaces                        NumFaces                        0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B0698TaiLSNTb0000001B0694NumFaces                        0000001B042EMapId                           0000001B06B0Vertices                        0000001B07BECells                           0000001D082EProstarFaceId                   0000001E011AProstarRegionNumber             0000001E0958unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001B06ACd   dEnDNoDeMapId                           MapId                           0000000000000000000000001000I4
             0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B07A6TaiLDaTa0000001B07BA   dEnDNoDeVertices                        Vertices                        00000010000000120000001D0000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B0B3ATaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B0B1ETaiLFreE0000001B0B1A000000190C68xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000001B0B36ô      dEnDDaTa0000001B0BCA
+         dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B0CC4TaiLDaTa0000001B0D54
+                                       dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001B0E4ETaiLDaTa0000001B0EDE                                          +   %                                                   dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C0000TaiLzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzDaTa0000001C0090                                 *   0
+   1   +                            !                dEnDNoDeExtendedData-4                  extendedData
     0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C018ATaiLDaTa0000001C021A"   !            #   "            $   #         0   6
+      7   1         6   <               =   7   dEnDNoDeExtendedData-5                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C0314TaiLDaTa0000001C03A4      <   B               C   =         B   H   $      %   +   O   I      *   N   T   0      +   1   U   O      0   dEnDNoDeExtendedData-6                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C049ETaiLDaTa0000001C052ET
   Z   6      1   7   [   U      6   Z   `   <      7   =   a   [      <   `   f   B      =   C   g   a      B   f   l   dEnDNoDeExtendedData-7                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C0628TaiLDaTa0000001C06B8H      I   O   s   m      N   r   x   T      O   U   y   s      T   x   ~   Z      U   [      y      Z   ~      `      dEnDNoDeExtendedData-8                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C09D6TaiLFreE0000001C09D20000001B09AAxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa0000001C0A66[   a
         `         f      a   g
      f         l      m   s            r         x      s   y   dEnDNoDeExtendedData-9                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C0B60TaiLDaTa0000001C0BF0         x      ¢   ~      y      £         ~   ¢   ¨
      ¯   ©   dEnDNoDeExtendedData-10                 extendedData                    0000000000000000000000001000I4
           0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C0CEATaiLDaTa0000001C0D7A      ®   ´               »   µ         º   À               Á   »         À   Æ   ¢         £   Ç   Á      ¢   dEnDNoDeExtendedData-11                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001C0E74TaiLDaTa0000001C0F04Æ   Ì   ¨      £   ©   Í   Ç      µ   »   ¼   ¶      ¶   ¼   ½   ·      ·   ½   ¾   ¸      ¸   ¾   ¿   ¹      ¹   ¿   À   dEnDNoDeExtendedData-12                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D032CTaiLzzSNTb0000001D0328ExtendedSize                    0000001B08B4ExtendedDat
 a-1                  0000001B0BCEExtendedData-2                  0000001B0D58ExtendedData-3                  0000001B0EE2ExtendedData-4                  0000001C0094ExtendedData-5                  0000001C021EExtendedData-6                  0000001C03A8ExtendedData-7                  0000001C0532ExtendedData-8                  0000001C06BCExtendedData-9                  0000001C0A6AExtendedData-10                 0000001C0BF4ExtendedData-11                 0000001C0D7EExtendedData-12                 0000001C0F08ExtendedData-13                 0000001D03C0ExtendedData-14                 0000001D054AExtendedData-15                 0000001D06D4unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001D03BCº      ¨   Ì   Ò   ®      ©   ¯   Ó   Í      »   Á   Â   ¼      ¼   Â   Ã   ½      ½   Ã   Ä   ¾      ¾   Ä   Å   ¿      dEnDNoDeExtendedData-13                 extendedData                    0000000000000000000000001000I4
                             0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D04B6TaiLDaTa0000001D0546¿   Å   Æ   À      ®   Ò   Ø   ´      Á   Ç   È   Â      Â   È   É   Ã      Ã   É   Ê   Ä      Ä   Ê   Ë   Å      Å   Ë   dEnDNoDeExtendedData-14                 extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D0640TaiLDaTa0000001D06D0Ì   Æ      Ç   Í   Î   È      È   Î   Ï   É      É   Ï   Ð   Ê      Ê   Ð   Ñ   Ë      Ë   Ñ   Ò   Ì      Í   Ó   Ô   Î   dEnDNoDeExtendedData-15                 extendedData                    0000000000000000000000001000I4                              0100000014000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D07CATaiLDaTa0000001D082A   Î   Ô   Õ   Ï      Ï   Õ   Ö   Ð
     Ð   Ö   ×   Ñ      Ñ   ×   Ø   Ò   dEnDNoDeCells                           Cells                           00000004000000080000001D0A1AI4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D0BAATaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D0B8ETaiLSNTb0000001D0B8AExtendedSize                    0000001D0924ExtendedData-1                  0000001D0C3EExtendedData-2                  0000001D0DC8ExtendedData-3                  0000001E0000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001D0BA6d       dEnDDaTa0000001D0C3A
+            dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D0D34TaiLDaTa0000001D0DC4                  #   $   (   )   -   .   2   3   7   8   <   =   A   B   F   G   K   L   P   Q   U   V   Z   [   _   `   dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001D0EBETaiLDaTa0000001D0F4Ed   e   i   j   n   o   s   t   e   f   g   h   i   x   y   j   k   l   m   n   }   o   p   q   r   s   t   u   v   w   x   y   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeExte
 ndedData-3                  extendedData                    0000000000000000000000001000I4                              0100000004000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E00F6TaiLDaTa0000001E0116z   {   |   }   dEnDNoDeProstarFaceId                   ProstarFaceId                   00000004000000080000001E0306I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E0496TaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E047ATaiLSNTb0000001E0476ExtendedSize                    0000001E0210ExtendedData-1                  0000001E052AExtendedData-2                  0000001E06B4ExtendedData-3                  0000001E083Eunused entry in sub-node-table
  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001E0492d       dEnDDaTa0000001E0526        dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E0620TaiLDaTa0000001E06B0        dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E07AATaiLDaTa0000001E083A
        dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              0100000004000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E0934TaiLDaTa0000001E0954            dEnDNoDeProstarRegionNumber             ProstarRegionNumber             0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E0A4ETaiLDaTa0000001E0A62    dEnDNoDeBoundaryFaces-1                 boundaryFaces                   00000008000000080000001F0264MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeMap-5                           map
  00000003000000080000001E0D48MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeLabel                           Label                           0000000000000000000000001000C1                              0100000008000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001E0EBCTaiLSNTb0000001E0EB8Label                           0000001E0C52MaximumMappedId                 0000001E0ED8IdMap                           0000001F0000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001E0ED4Face mapdEnDNoDeMaximumMappedId                 MaximumMappedId                 0000000000000000000000001000I4                              010000000100000000000000000000000000
 0000000000000000000000000000000000000000000000000000000000000000010000001E0FCETaiLDaTa0000001E0FE2k  dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeIdMap                           IdMap                           0000000000000000000000001000I4                              0100000019000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F00F6TaiLDaTa0000001F016A               c   e   g   i   l   ¸   º   ¼   ¾   Á
+          b  d  f  h  k  dEnDNoDeNumFaces                        NumFaces                        0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F03D8TaiLSNTb0000001F03D4NumFaces                        0000001F016EMapId                           0000001F03F0Vertices                        0000001F04FECells                           0000001F0DA0ProstarFaceId                   000000200000Radiatio
 nPatches                00000020016EProstarRegionNumber             0000002002DCGlobalBoundId                   0000002003EAsnTEDaTa0000001F03EC   dEnDNoDeMapId                           MapId                           0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F04E6TaiLDaTa0000001F04FA   dEnDNoDeVertices                        Vertices                        00000004000000080000001F06EAI4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F087ATaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F085ETaiLSNTb0000001F085AExtendedSize                    0000001F05F4ExtendedData-1
                  0000001F090EExtendedData-2                  0000001F0A98ExtendedData-3                  0000001F0C22unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000001F0876}       dEnDDaTa0000001F090A      %   &            &   '            '   (            (   )            )   *         %   I   J   &      &   dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F0A04TaiLDaTa0000001F0A94J   K   '      '   K   L   (      (   L   M   )      )   M   N   *      I   m   n   J      J   n   o   K      K   o   p   dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4
       0100000020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F0B8ETaiLDaTa0000001F0C1EL      L   p   q   M      M   q   r   N      m         n      n         o      o         p      p         q      dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              010000001D000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F0D18TaiLDaTa0000001F0D9Cq         r         µ   ¶            ¶   ·            ·   ¸            ¸   ¹            ¹   º      dEnDNoDeCells                           Cells                           0000000000000000000000001000I4                              0100000019000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000001F0E96TaiLDaTa0000001F0F0A                              3   4   5   6   7   L   M   N   O
    P   e   f   g   h   i   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeProstarFaceId                   ProstarFaceId                   0000000000000000000000001000I4                              0100000019000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002000F6TaiLDaTa00000020016A        dEnDNoDeRadiationPatches                RadiationPatches                0000000000000000000000001000I4                              010000001900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000200264TaiLDaTa0000002002D8
             dEnDNoDeProstarRegionNumber             ProstarRegionNumber             0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002003D2TaiLDaTa0000002003E6   dEnDNoDeGlobalBoundId                   GlobalBoundId                   0000000000000000000000001000I4                              0100000019000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002004E0TaiLDaTa000000200554
+               dEnDNoDeBoundaryFaces-2                 boundaryFaces                   0000000800000008000000200D3CMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeMap-6                           map                             000000030000000800000020083AMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeLabel                           Label                           0000000000000000000000001000C1                              0100000008000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002009AETaiLSNTb0000002009AALabel                           000000200744MaximumMappedId                 0000002009CAIdMap                           000000200AD8unused entry in sub-node-table  000000001000unused
 entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa0000002009C6Face mapdEnDNoDeMaximumMappedId                 MaximumMappedId                 0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000200AC0TaiLDaTa000000200AD4´  dEnDNoDeIdMap                           IdMap                           0000000000000000000000001000I4                              010000001900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000200BCETaiLDaTa000000200C42W   Z   ]   ^   `   ¬   ¯   ²   ³   µ
+  V  Y  \  ]  _  «  ®  ±  ²  ´  dEnDNoDeNumFaces                        NumFaces                        0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000200EB0TaiLSNTb000000200EACNumFaces                        000000200C46MapId                           000000200EC8Vertices                        000000210000Cells                           0000002108A2ProstarFaceId                   000000210A10RadiationPatches                000000210B7EProstarRegionNumber             000000210CECGlobalBoundId                   000000210DFAsnTEDaTa000000200EC4   dEnDNoDeMapId                           MapId                           0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000200FBETaiLDaTa000000200FD2   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
 zzzzzzzzzzzzNoDeVertices                        Vertices                        00000004000000080000002101ECI4                              01000000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000021037CTaiLNoDeExtendedSize                    extendedData                    0000000000000000000000001000I8                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210360TaiLSNTb00000021035CExtendedSize                    0000002100F6ExtendedData-1                  000000210410ExtendedData-2                  00000021059AExtendedData-3                  000000210724unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000210378}       dEnDDaTa00000021040C          D   C          !   E   D      !   "   F   E      "   #
    G   F      #   $   H   G      C   D   h   g      D   dEnDNoDeExtendedData-1                  extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210506TaiLDaTa000000210596E   i   h      E   F   j   i      F   G   k   j      G   H   l   k      g   h            h   i            i   j      dEnDNoDeExtendedData-2                  extendedData                    0000000000000000000000001000I4                              010000002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210690TaiLDaTa000000210720      j   k            k   l                  °   ¯            ±   °            ²   ±            ³   ²      dEnDNoDeExtendedData-3                  extendedData                    0000000000000000000000001000I4                              010000001D
 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000021081ATaiLDaTa00000021089E      ´   ³      ¯   °   Ô   Ó      °   ±   Õ   Ô      ±   ²   Ö   Õ      ²   ³   ×   Ö      ³   ´   Ø   ×   dEnDNoDeCells                           Cells                           0000000000000000000000001000I4                              010000001900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210998TaiLDaTa000000210A0C               .   /   0   1   2   G   H   I   J   K   `   a   b   c   d   y   z   {   |   }   dEnDNoDeProstarFaceId                   ProstarFaceId                   0000000000000000000000001000I4                              010000001900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210B06TaiLDaTa000000210B7A        dEnDNoDeRadiation
 Patches                RadiationPatches                0000000000000000000000001000I4                              010000001900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210C74TaiLDaTa000000210CE8        dEnDNoDeProstarRegionNumber             ProstarRegionNumber             0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210DE2TaiLDaTa000000210DF6   dEnDNoDeGlobalBoundId                   GlobalBoundId                   0000000000000000000000001000I4                              010000001900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000210EF0TaiLDaTa000000210F64*   +   -   /   1   ,         !   #   .             $   0   "         %   2   (   &   '   )   dEnD
 zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeVerticesFile                    VerticesFile                    0000000000000000000000001000C1                              0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002200F6TaiLDaTa000000220107 dEnDNoDeVerticesId                      VerticesId                      0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000220201TaiLDaTa000000220215   dEnDNoDeTopologyFile                    TopologyFile                    0000000000000000000000001000C1                              00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000022030FTaiLDaTa000000220320 dEnDNoDeTopologyId
    TopologyId                      0000000000000000000000001000I4                              01000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000022041ATaiLDaTa00000022042E   dEnDNoDeProblemDescriptions             problemDescription              000000010000000800000022061EMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeProblemDescription-1            problemDescription              0000000400000008000000220888MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb00000022078EProblemDescription-1            000000220528unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node
 -table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeCellType-1                      cellType                        0000000C0000000C00000023052EMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLSNTb0000002209F8CellType-1                      000000220792BoundaryRegion-0                000000230A94BoundaryRegion-1                00000024010EBoundaryRegion-2                000000240595unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTENoDeLabel                           Label                           0000000000000000000000001000C1                              010000000D00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000220C66TaiLFreE000000220
 C620000001C07B2xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxEndCDaTa000000220C83Default_FluiddEnDNoDeMaterialType                    MaterialType                    0000000000000000000000001000C1                              010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000220D7DTaiLDaTa000000220D92fluiddEnDNoDeRadiation                       Radiation                       0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000220E8CTaiLDaTa000000220EA0    dEnDNoDeMaterialId                      MaterialId
             0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000220F9ATaiLDaTa000000220FAE   dEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDePorosityId                      PorosityId                      0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002300F6TaiLDaTa00000023010A    dEnDNoDeSpinId                          SpinId                          0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000230204TaiLDaTa000000230218   dEnDNoDeGroupId                         GroupId                         0000000000000000000000001000I4                              01000000010000000000000000000
 0000000000000000000000000000000000000000000000000000000000000000000000001000000230312TaiLDaTa000000230326    dEnDNoDeColorIdx                        ColorIdx                        0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000230420TaiLDaTa000000230434   dEnDNoDeProcessorId                     ProcessorId                     0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000230752TaiLSNTb00000023074ELabel                           0000002209FCMaterialType                    000000220C87Radiation                       000000220D96MaterialId                      000000220EA4PorosityId                      000000230000SpinId                          00000023010EGroupId                         00000023021CColorIdx                        0000
 0023032AProcessorId                     000000230438LightMaterial                   00000023076AThickness                       000000230878FreeSurfaceMaterial             000000230986snTEDaTa000000230766    dEnDNoDeLightMaterial                   LightMaterial                   0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000230860TaiLDaTa000000230874   dEnDNoDeThickness                       Thickness                       0000000000000000000000001000R4                              01000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000023096ETaiLDaTa000000230982    dEnDNoDeFreeSurfaceMaterial             FreeSurfaceMaterial             0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002
 30A7CTaiLDaTa000000230A90    dEnDNoDeBoundaryRegion-0                boundaryRegion                  0000000300000008000000230C80MT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeBoundaryType                    BoundaryType                    0000000000000000000000001000C1                              010000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000230DF4TaiLSNTb000000230DF0BoundaryType                    000000230B8ABoundaryName                    000000230E0CProstarRegionNumber             000000240000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000230E08walldEnDNoDeBoundaryName                    BoundaryName
 0000000000000000000000001000C1                              010000001700000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000230F02TaiLDaTa000000230F29Default_Boundary_RegiondEnDzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzNoDeProstarRegionNumber             ProstarRegionNumber             0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002400F6TaiLDaTa00000024010A    dEnDNoDeBoundaryRegion-1                boundaryRegion                  00000002000000080000002402FAMT                              000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeBoundaryType                    Bound
 aryType                    0000000000000000000000001000C1                              01000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000024046ETaiLSNTb00000024046ABoundaryType                    000000240204ProstarRegionNumber             000000240487unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa000000240483inletdEnDNoDeProstarRegionNumber             ProstarRegionNumber             0000000000000000000000001000I4                              01000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000024057DTaiLDaTa000000240591   dEnDNoDeBoundaryRegion-2                boundaryRegion                  0000000200000008000000240781MT
            000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000TaiLNoDeBoundaryType                    BoundaryType                    0000000000000000000000001000C1                              0100000006000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000002408F5TaiLSNTb0000002408F1BoundaryType                    00000024068BProstarRegionNumber             00000024090Funused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000unused entry in sub-node-table  000000001000snTEDaTa00000024090BoutletdEnDNoDeProstarRegionNumber             ProstarRegionNumber             0000000000000000000000001000I4                              0100000001000000000000000000000000000000000000000000000000000000000000000000000000000000
 00000000000001000000240A05TaiLDaTa000000240A19   dEnDNoDeProblemDescription              ProblemDescription              0000000000000000000000001000I4                              010000000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000240B13TaiLDaTa000000240B27   dEnD
\ No newline at end of file
Modified: MOAB/trunk/src/io/ReadCCMIO.cpp
--- MOAB/trunk/src/io/ReadCCMIO.cpp	2010-05-21 21:12:46 UTC (rev 3940)
+++ MOAB/trunk/src/io/ReadCCMIO.cpp	2010-05-21 23:55:08 UTC (rev 3941)
@@ -136,6 +136,11 @@
     result = impl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
                               MB_TYPE_INTEGER, mGlobalIdTag, &dum_val);
+  result = impl->tag_get_handle(NAME_TAG_NAME, mNameTag);
+  if (MB_TAG_NOT_FOUND == result)
+    result = impl->tag_create(NAME_TAG_NAME, NAME_TAG_SIZE, MB_TAG_SPARSE,
+                              MB_TYPE_OPAQUE, mNameTag, NULL);
 ReadCCMIO::~ReadCCMIO()
@@ -240,8 +245,8 @@
   rval = load_matset_data(problemID);
   CHKERR(rval, "Failure loading matset data.");
-//  rval = load_neuset_data(problemID);
-//  CHKERR(rval, "Failure loading neuset data.");
+  rval = load_neuset_data(problemID);
+  CHKERR(rval, "Failure loading neuset data.");
