[MOAB-dev] r3934 - MOAB/trunk/test/parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu May 20 17:34:19 CDT 2010
Author: kraftche
Date: 2010-05-20 17:34:19 -0500 (Thu, 20 May 2010)
New Revision: 3934
Modified:
   MOAB/trunk/test/parallel/parallel_hdf5_test.cc
Log:
add command line flags to enable debug output to parallel hdf5 test
Modified: MOAB/trunk/test/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/test/parallel/parallel_hdf5_test.cc	2010-05-20 22:27:35 UTC (rev 3933)
+++ MOAB/trunk/test/parallel/parallel_hdf5_test.cc	2010-05-20 22:34:19 UTC (rev 3934)
@@ -50,6 +50,8 @@
 bool KeepTmpFiles = false;
 bool PauseOnStart = false;
 const int DefaultReadIntervals = 2;
+int ReadDebugLevel = 0;
+int WriteDebugLevel = 0;
 int main( int argc, char* argv[] )
@@ -61,14 +63,26 @@
       KeepTmpFiles = true;
     else if (!strcmp( argv[i], "-p"))
       PauseOnStart = true;
-    else if (!strcmp( argv[i], "-r")) {
+    else if (!strcmp( argv[i], "-R")) {
       ++i;
       CHECK( i < argc );
       ReadIntervals = atoi( argv[i] );
       CHECK( ReadIntervals > 0 );
+    else if (!strcmp( argv[i], "-r")) {
+      ++i;
+      CHECK( i < argc );
+      ReadDebugLevel = atoi( argv[i] );
+      CHECK( ReadDebugLevel > 0 );
+    else if (!strcmp( argv[i], "-w")) {
+      ++i;
+      WriteDebugLevel = atoi( argv[i] );
+      CHECK( WriteDebugLevel > 0 );
     else {
-      std::cerr << "Usage: " << argv[0] << " [-k] [-p] [-r <int>]" << std::endl;
+      std::cerr << "Usage: " << argv[0] << " [-k] [-p] [-R <intervals>] [-r <level>] [-w <level>]" << std::endl;
       return 1;
@@ -283,7 +297,15 @@
   int procnum;
   MPI_Comm_rank( MPI_COMM_WORLD, &procnum );
-  rval = moab.write_file( tmp_filename, 0, "PARALLEL=WRITE_PART" );
+  const char* opt = "PARALLEL=WRITE_PART";
+  std::string str;
+  if (WriteDebugLevel) {
+    std::ostringstream s;
