[MOAB-dev] r3929 - in MOAB/trunk: src src/moab test
kraftche at cae.wisc.edu
Thu May 20 12:21:23 CDT 2010
Author: kraftche
Date: 2010-05-20 12:21:23 -0500 (Thu, 20 May 2010)
New Revision: 3929
Modified:
MOAB/trunk/src/Range.cpp
MOAB/trunk/src/moab/Range.hpp
MOAB/trunk/test/MBTest.cpp
Log:
add method to test if one range is a non-strict subset of another
Modified: MOAB/trunk/src/Range.cpp
--- MOAB/trunk/src/Range.cpp 2010-05-20 17:06:55 UTC (rev 3928)
+++ MOAB/trunk/src/Range.cpp 2010-05-20 17:21:23 UTC (rev 3929)
@@ -1015,6 +1015,44 @@
result += sizeof(PairNode);
return result;
+bool Range::contains( const Range& othr ) const
+ if (othr.empty())
+ return true;
+ if (empty())
+ return false;
+ // neither range is empty, so both have valid pair nodes
+ // other than dummy mHead
+ const PairNode* this_node = mHead.mNext;
+ const PairNode* othr_node = othr.mHead.mNext;
+ for(;;) {
+ // Loop while the node in this list is entirely before
+ // the node in the other list.
+ while (this_node->second < othr_node->first) {
+ this_node = this_node->mNext;
+ if (this_node == &mHead)
+ return false;
+ // If other node is not entirely contained in this node
+ // then other list is not contained in this list
+ if (this_node->first > othr_node->first)
+ return false;
+ // Loop while other node is entirely contained in this node.
+ while (othr_node->second <= this_node->second) {
+ othr_node = othr_node->mNext;
+ if (othr_node == &othr.mHead)
+ return true;
+ // If other node overlapped end of this node
+ if (othr_node->first <= this_node->second)
+ return false;
+ // should be unreachable
+ return false;
} // namespace moab
Modified: MOAB/trunk/src/moab/Range.hpp
