[MOAB-dev] r3927 - in MOAB/trunk: MeshFiles MeshFiles/unittest test
    Tim Tautges
    tautges at mcs.anl.gov
    Thu May 20 09:34:36 CDT 2010
Thanks Jason, that was definitely my bad.
- tim
On 05/20/2010 09:27 AM, kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-05-20 09:27:49 -0500 (Thu, 20 May 2010)
> New Revision: 3927
> Modified:
>     MOAB/trunk/MeshFiles/Makefile.am
>     MOAB/trunk/MeshFiles/unittest/Makefile.am
>     MOAB/trunk/test/Makefile.am
> Log:
> uncompress exodus files used by MBTest into ${top_builddir}/test because it \
> a) fixes failing moab_test and \
> b) keeps the the source dir read-only when it is not the same as the build dir
> Modified: MOAB/trunk/MeshFiles/Makefile.am
> --- MOAB/trunk/MeshFiles/Makefile.am	2010-05-20 14:26:06 UTC (rev 3926)
> +++ MOAB/trunk/MeshFiles/Makefile.am	2010-05-20 14:27:49 UTC (rev 3927)
> @@ -1 +1,2 @@
>   SUBDIRS = unittest
> +EXTRA_DIST = singlecyl.cub cinglecyl.h5m README
> Modified: MOAB/trunk/MeshFiles/unittest/Makefile.am
> --- MOAB/trunk/MeshFiles/unittest/Makefile.am	2010-05-20 14:26:06 UTC (rev 3926)
> +++ MOAB/trunk/MeshFiles/unittest/Makefile.am	2010-05-20 14:27:49 UTC (rev 3927)
> @@ -22,7 +22,3 @@
>   	      ptest.cub \
>                 64bricks_512hex.h5m
> -CLEANFILES = mb_big_test.g \
> -             cell1.gen \
> -             cell2.gen
> Modified: MOAB/trunk/test/Makefile.am
> --- MOAB/trunk/test/Makefile.am	2010-05-20 14:26:06 UTC (rev 3926)
> +++ MOAB/trunk/test/Makefile.am	2010-05-20 14:27:49 UTC (rev 3927)
> @@ -60,9 +60,9 @@
>   moab_test_SOURCES = MBTest.cpp
>   moab_test_DEPENDENCIES = \
> -	$(top_srcdir)/MeshFiles/unittest/mb_big_test.g \
> -	$(top_srcdir)/MeshFiles/unittest/cell1.gen \
> -	$(top_srcdir)/MeshFiles/unittest/cell2.gen \
> +	mb_big_test.g \
> +	cell1.gen \
> +	cell2.gen \
>   	$(LDADD)
>   homxform_test_SOURCES = $(top_srcdir)/src/HomXform.cpp
> @@ -131,16 +131,20 @@
>   bsp_tree_poly_test_SOURCES = bsp_tree_poly_test.cpp
> -$(MESHDIR)/mb_big_test.g: $(MESHDIR)/mb_big_test.g.gz
> +mb_big_test.g: $(MESHDIR)/mb_big_test.g.gz
>   	$(ZCAT) $<  >  $@
> -$(MESHDIR)/cell1.gen: $(MESHDIR)/cell1.gen.gz
> +cell1.gen: $(MESHDIR)/cell1.gen.gz
>   	$(ZCAT) $<  >  $@
> -$(MESHDIR)/cell2.gen: $(MESHDIR)/cell2.gen.gz
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
