[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Thu May 20 00:10:43 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/154
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
	  fi; \
	done
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/src/io/mhdf'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/src/oldinc'
make[2]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test'
list='. io dual obb perf h5file parallel oldinc'; for subdir in $list; do \
	  if test "$subdir" = .; then :; else \
	    test -d "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/test/$subdir" \
	    || /bin/mkdir -p "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/test/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/test && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        top_distdir="$top_distdir" \
	        distdir="$distdir/$subdir" \
		am__remove_distdir=: \
		am__skip_length_check=: \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/io'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/dual'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/obb'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/perf'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/h5file'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/parallel'
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/test/oldinc'
make[2]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/itaps'
list='imesh igeom'; for subdir in $list; do \
	    test -d "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/itaps/$subdir" \
	    || /bin/mkdir -p "/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/itaps/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/itaps && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/itaps/imesh'
./../mkprotos.sh iMesh MOAB iMesh.h iMesh_protos.h MOAB_FCDefs.h
make[3]: *** No rule to make target `moabtest.F', needed by `distdir'.  Stop.
sincerely,
 -The Fathomatic
