[MOAB-dev] error in mbsize and problem using debugger
    Rajeev Jain
    jain at mcs.anl.gov
    Wed May 19 15:29:27 CDT 2010
I used Cubit 10.2 to make this mesh file. mbsize and mbconvert both work fine on this file. It's mbsize -ll that gives that throws an error.
Thanks for the explanation on shared build and using the debugger. I see that even in examples directory make creates a shell script instead of an executable. The executable in the hidden .libs directory, why are things designed this way?
Thanks,Rajeev
To: Rajeev Jain <jain at mcs.anl.gov>
Cc: "moab-dev at mcs.anl.gov" <moab-dev at mcs.anl.gov>
Sent: Wednesday, May 19, 2010 15:11:03
Subject: Re: [MOAB-dev] error in mbsize and problem using debugger
Rajeev Jain wrote:
> Using mbsize -ll for the attached file, I get an error: "Error
> processing mesh from file: pin1.cub" . This worked in previous revisions.
Try mbconvert.  The error message may be more informative.  What version of
Cubit did you use to create this file?  MOAB only supports reading files
generated by version 10.x.
- jason
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100519/a18fbb40/attachment.htm>
