[MOAB-dev] r3901 - in MOAB/trunk/src: io io/mhdf/include parallel
kraftche at cae.wisc.edu
Fri May 14 11:28:09 CDT 2010
Author: kraftche
Date: 2010-05-14 11:28:09 -0500 (Fri, 14 May 2010)
New Revision: 3901
Modified:
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/io/mhdf/include/mhdf.h
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
improved debug output and optional use of collective IO calls for WriteHDF5
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-14 16:27:17 UTC (rev 3900)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-14 16:28:09 UTC (rev 3901)
@@ -217,6 +217,12 @@
return (A); \
} while(false)
+#define debug_barrier() debug_barrier_line(__LINE__)
+void WriteHDF5::debug_barrier_line(int )
bool WriteHDF5::convert_handle_tag( const EntityHandle* source,
EntityHandle* dest, size_t count ) const
@@ -291,6 +297,8 @@
writeSetContents(false),
writeSetChildren(false),
writeSetParents(false),
+ parallelWrite(false),
+ collectiveIO(false),
writeProp( H5P_DEFAULT ),
dbgOut("H5M ", stderr)
@@ -339,22 +347,6 @@
return MB_SUCCESS;
-void WriteHDF5::tprint( const char* fmt, ... )
- if (dbgOut.get_verbosity()) {
- static const clock_t t0 = clock();
- va_list args;
- va_start(args, fmt);
- char buffer[128];
- size_t n = snprintf( buffer, sizeof(buffer), "%6.2f: ", (double)(clock()-t0)/CLOCKS_PER_SEC );
- vsnprintf( buffer+n, sizeof(buffer)-n, fmt, args );
- dbgOut.print(1,buffer);
- va_end(args);
WriteHDF5::~WriteHDF5()
if (!writeUtil) // init() failed.
@@ -375,6 +367,9 @@
int user_dimension )
