[MOAB-dev] r3896 - MOAB/trunk/tools
kraftche at cae.wisc.edu
Thu May 13 09:22:20 CDT 2010
Author: kraftche
Date: 2010-05-13 09:22:20 -0500 (Thu, 13 May 2010)
New Revision: 3896
Modified:
MOAB/trunk/tools/mbmem.cpp
Log:
Trival fixed to mbmem utility:
o Make -h print help like other MOAB utils do
o Changing existing -h option to -H
o Print error message for invalid flag (not just usage info)
Modified: MOAB/trunk/tools/mbmem.cpp
--- MOAB/trunk/tools/mbmem.cpp 2010-05-13 05:40:27 UTC (rev 3895)
+++ MOAB/trunk/tools/mbmem.cpp 2010-05-13 14:22:20 UTC (rev 3896)
@@ -14,18 +14,24 @@
#include <sys/resource.h>
#endif
-void usage( const char* argv0 )
+void usage( const char* argv0, bool help = false )
- std::cerr << "Usage: " << argv0 << " [-h|-b|-k|-m] <filename> [<filename> ...]" << std::endl
- << "Usage: " << argv0 << " [-h|-b|-k|-m] -T" << std::endl
- << " -h : human readable units" << std::endl
+ std::ostream& str = help ? std::cout : std::cerr;
+ str << "Usage: " << argv0 << " [-H|-b|-k|-m] <filename> [<filename> ...]" << std::endl
+ << " " << argv0 << " [-H|-b|-k|-m] -T" << std::endl;
+ if (!help) {
+ str << " " << argv0 << " -h" << std::endl;
+ std::exit(1);
+ std::cerr << " -H : human readable units" << std::endl
<< " -b : bytes" << std::endl
<< " -k : kilobytes (1 kB == 1024 bytes)" << std::endl
<< " -m : megabytes (1 MB == 1024 kB)" << std::endl
<< " -g : gigabytes (1 GB == 1024 MB)" << std::endl
<< " -T : test mode" << std::endl
<< std::endl;
- std::exit(1);
+ std::exit(0);
enum Units { HUMAN, BYTES, KILOBYTES, MEGABYTES, GIGABYTES };
@@ -52,7 +58,7 @@
// load each file specified on command line
for (int i = 1; i < argc; ++i) {
if (!no_more_flags && argv[i][0] == '-') {
- if (!strcmp(argv[i],"-h"))
+ if (!strcmp(argv[i],"-H"))
UNITS = HUMAN;
else if(!strcmp(argv[i],"-b"))
UNITS = BYTES;
@@ -64,10 +70,14 @@
UNITS = GIGABYTES;
else if(!strcmp(argv[i],"-T"))
test_mode = true;
+ else if(!strcmp(argv[i],"-h"))
+ usage(argv[0],true);
else if(!strcmp(argv[i],"--"))
no_more_flags = true;
