[MOAB-dev] r3873 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Mon May 10 14:54:02 CDT 2010
Author: kraftche
Date: 2010-05-10 14:54:02 -0500 (Mon, 10 May 2010)
New Revision: 3873
Modified:
MOAB/trunk/src/parallel/ReadParallel.cpp
MOAB/trunk/src/parallel/ReadParallel.hpp
Log:
make some debug output in ReadParallel run-time configurable
Modified: MOAB/trunk/src/parallel/ReadParallel.cpp
--- MOAB/trunk/src/parallel/ReadParallel.cpp 2010-05-10 19:53:32 UTC (rev 3872)
+++ MOAB/trunk/src/parallel/ReadParallel.cpp 2010-05-10 19:54:02 UTC (rev 3873)
@@ -45,12 +45,15 @@
ReadParallel::ReadParallel(Interface* impl,
ParallelComm *pc)
- : mbImpl(impl), myPcomm(pc)
+ : mbImpl(impl), myPcomm(pc), myDebug("ReadPara", std::cerr)
if (!myPcomm) {
myPcomm = ParallelComm::get_pcomm(mbImpl, 0);
if (NULL == myPcomm) myPcomm = new ParallelComm(mbImpl);
+ myDebug.set_rank( myPcomm->proc_config().proc_rank() );
+ if (debug) // for backwards compatability, enable all debug output if constant is true
+ myDebug.set_verbosity(10);
ErrorCode ReadParallel::load_file(const char **file_names,
@@ -62,6 +65,12 @@
const Tag* file_id_tag )
Error *merror = ((Core*)mbImpl)->get_error_handler();
+ int tmpval;
+ if (MB_SUCCESS == opts.get_int_option("DEBUG_PIO", 1, tmpval))
+ myDebug.set_verbosity(tmpval);
+ myDebug.tprint(1,"Setting up...\n");
// Get parallel settings
int parallel_mode;
@@ -169,6 +178,7 @@
switch (parallel_mode) {
case POPT_BCAST:
+ myDebug.print(1,"Read mode is BCAST\n");
if (is_reader) {
pa_vec.push_back(PA_READ);
pa_vec.push_back(PA_CHECK_GIDS_SERIAL);
@@ -180,6 +190,7 @@
break;
case POPT_BCAST_DELETE:
+ myDebug.print(1,"Read mode is BCAST_DELETE\n");
if (is_reader) {
@@ -192,6 +203,7 @@
