[MOAB-dev] r3855 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Wed May 5 18:08:28 CDT 2010
Author: kraftche
Date: 2010-05-05 18:08:28 -0500 (Wed, 05 May 2010)
New Revision: 3855
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
o Fix debug output in ReadHDF5
o When doing a partial read (e.g. parallel read) in ReadHDF5, ignore any
non-set entities tagged with the subset tag rather than failing.
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2010-05-05 23:07:17 UTC (rev 3854)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2010-05-05 23:08:28 UTC (rev 3855)
@@ -223,7 +223,7 @@
dbgOut.set_rank(rank);
// Open the file in serial on root to read summary
- dbgOut.print( 1, "Getting file summary" );
+ dbgOut.print( 1, "Getting file summary\n" );
fileInfo = 0;
unsigned long size = 0;
if (rank == 0) {
@@ -242,7 +242,7 @@
// Broadcast the size of the struct (zero indicates an error)
- dbgOut.print( 1, "Communicating file summary" );
+ dbgOut.print( 1, "Communicating file summary\n" );
int err = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, myPcomm->proc_config().proc_comm() );
if (err || !size)
return MB_FAILURE;
@@ -264,7 +264,7 @@
indepIO = native_parallel ? H5P_DEFAULT : collIO;
// re-open file in parallel
- dbgOut.printf( 1, "Re-opening \"%s\" for parallel IO", filename );
+ dbgOut.printf( 1, "Re-opening \"%s\" for parallel IO\n", filename );
filePtr = mhdf_openFileWithOpt( filename, 0, NULL, file_prop, &status );
H5Pclose( file_prop );
if (!filePtr)
@@ -495,10 +495,18 @@
if (subset_list[i].num_parts) {
// check that the tag only identified sets
- if ((unsigned long)fileInfo->sets.start_id > tmp_file_ids.front() ||
- tmp_file_ids.back() >= (unsigned long)fileInfo->sets.start_id + fileInfo->sets.count) {
- return error(MB_TYPE_OUT_OF_RANGE);
+ if ((unsigned long)fileInfo->sets.start_id > tmp_file_ids.front()) {
+ dbgOut.print(1,"Ignoreing non-set entities with partition set tag\n");
+ tmp_file_ids.erase( tmp_file_ids.begin(),
+ tmp_file_ids.lower_bound(
+ (EntityHandle)fileInfo->sets.start_id ) );
+ unsigned long set_end = (unsigned long)fileInfo->sets.start_id + fileInfo->sets.count;
+ if (tmp_file_ids.back() >= set_end) {
+ tmp_file_ids.erase( tmp_file_ids.upper_bound( (EntityHandle)set_end ),
+ tmp_file_ids.end() );
