[MOAB-dev] r3843 - MOAB/trunk
smithrm at mcs.anl.gov
Wed May 5 10:56:54 CDT 2010
Author: smithrm
Date: 2010-05-05 10:56:54 -0500 (Wed, 05 May 2010)
New Revision: 3843
Modified:
MOAB/trunk/KNOWN_ISSUES
Log:
o Updated with latest list of outstanding issues.
Modified: MOAB/trunk/KNOWN_ISSUES
--- MOAB/trunk/KNOWN_ISSUES 2010-05-04 20:31:36 UTC (rev 3842)
+++ MOAB/trunk/KNOWN_ISSUES 2010-05-05 15:56:54 UTC (rev 3843)
@@ -7,74 +7,28 @@
33 critical Parallel read failure for > 32procs
-34 critical Resolve shared entities bug in scdtest
-6 major ncdf load failure
-9 major MOAB has trouble loading the attached files
-10 major "For ilcend.cub, MOAB returns inconsistent numbers of VERTEXes for
- REGIONs, FACEs, etc"
-11 major Get the wrong number of lower/higher dimensional entities for a
- given entity with ilcend.cub
-28 major Adjacencies not right after entity creation
35 major MOAB parallel memory leak
-144 major Document need for MPI/IO for HDF5
149 major Usage notes for iMesh/iGeom on MOAB/CGM implementations
+161 major Need better MBCN test
-151 major Document usage of parallel moab with non-world communicators
+163 major Assertion failure reading 2 meshes in mbcoupler_test
-13 minor MOAB make check fails w/ clean build & no previous iMesh
22 minor iMesh_getAdjTable() is incorrect
29 minor Specifying sets not to write
