[MOAB-dev] Reader/Writer filename extension access
    Tim Tautges
    tautges at mcs.anl.gov
    Fri Apr 30 14:14:41 CDT 2010
Oops, forgot to add the important caveat that you'd only be asking about known extensions, and would only get back the
indication that the reader/writer was registered to handle that extension, not that it would successfully read any file
with that extension.
- tim
Jason Kraftcheck wrote:
> Tim Tautges wrote:
>> I think sometimes you want to know ahead of time which will be used.
> But sometimes MOAB doesn't know until after the file is read.  The most
> robust way to implement something like this would probably be to have each
> file reader implement a virtual function that checks whether or not the file
> is the correct format for the reader based on file internals.  Then provide
> some MOAB API to access that.  Perhaps an option to load_file that instructs
> it to only create the set tagged with the file type but not read in any data.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
