[MOAB-dev] Reader/Writer filename extension access
Tim Tautges
tautges at mcs.anl.gov
Fri Apr 30 13:22:59 CDT 2010
I think sometimes you want to know ahead of time which will be used.
- tim
Jason Kraftcheck wrote:
> Paul Wilson wrote:
>> It is difficult for a user to determine any kind of unique and robustly
>> identifying information about which reader actually was invoked (will be
>> invoked) to read the file in question from the MOAB API. Instead the
>> user tends to reimplement the same kind of code that MOAB uses (string
>> comparisons on filename extensions) but with little/no code reuse (don't
>> actually know which extensions are handled by which reader) and huge
>> potential for inconsistency.
> If it is sufficient to know which reader was used, why not have MOAB tag the
> file set with the file format that the data came from?
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
