[MOAB-dev] Reader/Writer filename extension access
Paul Wilson wilsonp at engr.wisc.edu
Fri Apr 30 12:40:37 CDT 2010
Robert Smith wrote:
> On Apr 30, 2010, at 9:05 AM, Jed Brown wrote:
>> On Fri, 30 Apr 2010 09:01:09 -0500, Robert Smith
>> <smithrm at mcs.anl.gov> wrote:
>>> What do you mean by "not part of the MOAB API"?  We can't dictate the
>>> structure of the Readers/Writers?
>> I think Jason's point was that it's unacceptable for client code to have
>> a dependency on the implementations.
> Do you mean the code that uses the Readers/Writers?  I would agree, it
> should not depend on the implementation.  But does that mean no client
> code can know which particular Reader/Writer it is using?  If that's
> true then the entire purpose of the ticket seems moot.
> If that's not what you mean then I don't see how my suggestions open
> the implementation to the users.  They are just new member functions.
I'm going to try to jump in here since I think some of our usage
patterns may have prompted the request for this.  (Ignore me if I am
wrong...)
With the current file handling capability of MOAB based on extension
and/or just trying a Reader until one works, user code can simply
forward a filename to the load_file method and get back some result.
However, the user may want to perform a variety of tasks in their code
based upon which kind of file was sent to MOAB.  For example, in DAGMC,
we may want to have some optional capabilities available if the user
provides an geometry file (ACIS) rather than a mesh file (MOAB).  This
is a run-time change in available features based on the format of the file.
It is difficult for a user to determine any kind of unique and robustly
identifying information about which reader actually was invoked (will be
invoked) to read the file in question from the MOAB API.  Instead the
user tends to reimplement the same kind of code that MOAB uses (string
comparisons on filename extensions) but with little/no code reuse (don't
actually know which extensions are handled by which reader) and huge
potential for inconsistency.
So, in summary, if the user code wants to branch based on which reader
is invoked by MOAB, it is not obvious how to do this robustly.  I think
this is the origin of this ticket???
Paul
Paul Wilson
Paul P.H. Wilson              419 Engineering Research Building
wilsonp at engr.wisc.edu                       1500 Engineering Dr
ph/fax: 608/263-0807                          Madison, WI 53706
           My calendar: http://bit.ly/pphw-calendar
       Computational Nuclear Engineering Research Group
               http://cnerg.engr.wisc.edu
          Associate Professor, Nuclear Engineering
              Engineering Physics Department
               http://www.engr.wisc.edu/ep
        Chair, Energy Analysis & Policy Certificate
         Nelson Institute for Environmental Studies
                http://nelson.wisc.edu/eap/
          Contributing to the joy and improvement
                  of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100430/56d06af4/attachment.bin>
