[MOAB-dev] Reader/Writer filename extension access
Jason Kraftcheck kraftche at cae.wisc.edu
Thu Apr 29 15:57:50 CDT 2010
Robert Smith wrote:
> I see 2 possibilities:
>     A - have a function that searches through the ReaderWriterSet list
> of registered factory methods and matches the factory method on a
> particular subclass of ReaderIface/WriterIface.
>     B - move the extensions to the actual Reader/Writer classes as a
> static data member that could be returned by either a static member
> function (for use in registration in ReaderWriterSet) or a virtual
> function defined on ReaderIface (for use to solve 2a) above).
Neither of these would be acceptable because the class definitions for
individual Reader/Writer implementations are not part of the MOAB API.
- jason
