[MOAB-dev] Reader/Writer filename extension access
Robert Smith
smithrm at mcs.anl.gov
Thu Apr 29 15:49:54 CDT 2010
I'm looking for some comments on Ticket #142 and my thoughts below.
Ticket #142 asks for 3 things from the Reader/Writer interface:
1) Given an extension or filename, get the name or actual
reader/writer that can handle it
2a) Get the extensions a reader/writer handles and
2b) possibly all the readers/writers registered.
I believe 1) is covered by the existing interface on ReaderWriterSet.
The get_file_extension_reader/ get_file_extension_writer functions do
this.
For 2b) this could be done fairly easily. Just return a vector of
ReaderIface* or WriterIface*. I'm not sure what this would be used
for but it could be done.
It is 2a) that is more tricky. Currently the extensions are
registered with a Reader and/or Writer factory method directly in the
ReaderWriterSet constructor. This is the only place the extensions
are known. What 2a) is asking is to go from an object instance of a
subclass of ReaderIface or WriterIface and retrieve these associated
extensions.
I see 2 possibilities:
A - have a function that searches through the ReaderWriterSet
list of registered factory methods and matches the factory method on a
particular subclass of ReaderIface/WriterIface.
B - move the extensions to the actual Reader/Writer classes as a
static data member that could be returned by either a static member
function (for use in registration in ReaderWriterSet) or a virtual
function defined on ReaderIface (for use to solve 2a) above).
I'm not sure 'A' really works but it seems as though it should.
ReaderIface/WriterIface would have new virtual functions to request
the information. These would be implemented in the Reader/Writer
classes as requests to the ReaderWriterSet passing in the function
pointer of their own static factory function.
For 'B' the technical aspects of the implementation are
straightforward. The complication comes from the fact that you can
register a Reader, a Writer or both for a set of extensions. To do
'B' simply we could put the static extension data into both a Reader
and Writer class if both existed. And then in ReaderWriterSet just
choose which one you would use in the registration.
This is not ideal as we have duplicated data. A possible solution
would be to add in IoXxx classes (I'm open to better names). For
example, create an IoGmsh class. It would have the extensions as
static data and methods to access them. This IoGmsh class could also
contain the format name string and description strings also.
ReaderGmsh/WriterGmsh would then inherit from this IoGmsh class in
addition to ReaderIface. See attached file for example code.
This implementation could also handle the instances of multiple
extension sets and format names as is the case for ReadCGM by making
the extensions an array of arrays of char* and the format an array of
char*.
My preferred approach would be 'A' as it involves little disruption to
the current design. But I'm not sure it will work. Option 'B'
involves more changes and multiple inheritance.
I'm also wondering at the utility of this functionality in the first
place. When would someone have a ReaderIface* to a Reader/Writer
object and want to know the extensions it supports?
Any thoughts would be appreciated.
--Bob
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100429/3aa2b44a/attachment.txt>
