[MOAB-dev] r3819 - MOAB/trunk/src/io
    smithrm at mcs.anl.gov
    Mon Apr 26 13:23:56 CDT 2010
Author: smithrm
Date: 2010-04-26 13:23:56 -0500 (Mon, 26 Apr 2010)
New Revision: 3819
Modified:
   MOAB/trunk/src/io/ReadNCDF.cpp
Log:
o Added 3 NULL return checks in read_exodus_header().  Fixes ticket #6.
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp	2010-04-26 18:19:56 UTC (rev 3818)
+++ MOAB/trunk/src/io/ReadNCDF.cpp	2010-04-26 18:23:56 UTC (rev 3819)
@@ -371,7 +371,12 @@
     // get the word size, scalar value
   NcAtt *temp_att = ncFile->get_att("floating_point_word_size");
-  if (!temp_att->is_valid() || temp_att->type() != ncInt || temp_att->num_vals() != 1) {
+  if (NULL == temp_att || !temp_att->is_valid()) {
+    readMeshIface->report_error("ReadNCDF:: Problem getting floating_point_word_size attribute.");
+    delete temp_att;
+    return MB_FAILURE;
+  if (temp_att->type() != ncInt || temp_att->num_vals() != 1) {
     readMeshIface->report_error("ReadNCDF:: Word size didn't have type int or size 1.");
     return MB_FAILURE;
@@ -380,7 +385,12 @@
     // exodus version
   temp_att = ncFile->get_att("version");
-  if (!temp_att->is_valid() || temp_att->type() != ncFloat || temp_att->num_vals() != 1) {
+    readMeshIface->report_error("ReadNCDF:: Problem getting version attribute.");
+    delete temp_att;
+  if (temp_att->type() != ncFloat || temp_att->num_vals() != 1) {
     readMeshIface->report_error("ReadNCDF:: Version didn't have type float or size 1.");
     return MB_FAILURE;
@@ -403,7 +413,12 @@
     // title
   char *title = new char[max_line_length+1];
   temp_att = ncFile->get_att("title");
-  if (temp_att->is_valid() && temp_att->num_vals() == 1) {
+    readMeshIface->report_error("ReadNCDF:: Problem getting title attribute.");
+    delete temp_att;
+  if (temp_att->num_vals() == 1) {
     char *dum_str = temp_att->as_string(0);
     strcpy(title, dum_str);
     delete dum_str;
