[MOAB-dev] Getting ent set data when tag_size > 1
    James Porter
    jvporter at wisc.edu
    Wed Apr 21 19:28:35 CDT 2010
For what it's worth, I ultimately decided to stop using the
type-specific functions for getting/setting tag data in Python since
those functions are crippled (esp. for sets) and required considerably
more work to pick the right function.
I know this works fine for MOAB, but is it actually a requirement of the
ITAPS interface that iMesh_getData works correctly no matter the
underlying type? If not, it should be in my opinion.
- Jim
On Fri, 2010-04-16 at 15:27 -0500, James Porter wrote:
> On Tue, 2010-04-13 at 13:34 -0500, Tim Tautges wrote:
> > Jed Brown wrote:
> > > There ought to be get/setEntSetArrData (in fact, I would only expose the
> > > array interface because the single-tag versions are crippled and not
> > > more usable).
> > Agreed.  I'll put that on the list of extensions to write, and will propose it to itaps (nobody else really uses sets in
> > any serious way, so that's probably why it hasn't come up there).
> Attached is what I personally would like to see in terms of interface.
> Main points:
> * No type-specific functions (uses void* everywhere)
> * get/set functions that take in arrays of entity sets
> * get/set functions for arrays of entities/sets take a storage order
> It would be pretty easy to write type-specific wrappers for these, which
> I think is the best way to go.
> - Jim
