[MOAB-dev] r3797 - in MOAB/trunk: src/io tools/dagmc
bmsmith6 at wisc.edu
Wed Apr 21 10:03:57 CDT 2010
Author: bmsmith
Date: 2010-04-21 10:03:57 -0500 (Wed, 21 Apr 2010)
New Revision: 3797
Modified:
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/tools/dagmc/cub2h5m.cc
Log:
Tolerance needs increased for 85pin 1/12 symmetry space reactor model.
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp 2010-04-20 23:02:20 UTC (rev 3796)
+++ MOAB/trunk/src/io/ReadNCDF.cpp 2010-04-21 15:03:57 UTC (rev 3797)
@@ -1850,7 +1850,9 @@
// search is O(logn) but MOAB tag search is O(n). For 150k nodes this
// is 5 minutes faster. The MAX_NODE_DIST is the farthest that we will search
// for a node. Note that the exodus file is single precision.
- const double MAX_NODE_DIST = 1e-3;
+ // For the 1/12th symmetry 85 pin model, the max node dist could not be less
+ // than 1e-1 (March 26, 2010).
+ const double MAX_NODE_DIST = 1e-1;
std::cout << " exodus file contains " << numberNodes_loading << " nodes."
<< std::endl;
for(int i=0; i<numberNodes_loading; ++i) {
@@ -1912,7 +1914,7 @@
average_magnitude += magnitude;
} else {
++lost;
- //std::cout << "cannot match exo vert=" << exo_coords << std::endl;
+ std::cout << "cannot match exo vert " << exo_id << " " << exo_coords << std::endl;
Modified: MOAB/trunk/tools/dagmc/cub2h5m.cc
--- MOAB/trunk/tools/dagmc/cub2h5m.cc 2010-04-20 23:02:20 UTC (rev 3796)
+++ MOAB/trunk/tools/dagmc/cub2h5m.cc 2010-04-21 15:03:57 UTC (rev 3797)
@@ -948,7 +948,7 @@
if(4!=argc && 6!=argc && 7!=argc)
std::cerr << "To read meshed geometry for DagMC:" << std::endl;
- std::cerr << "$> cub_file acis_file output_file" << std::endl;
+ std::cerr << "$> <cub_file.cub> <acis_file.sat> <output_file.h5m>" << std::endl;
std::cerr << "To read meshed geometry for DagMC and update node coordinates:" << std::endl;
std::cerr << "$> <cub_file.cub> <acis_file.sat> <output_file.h5m> <deformed_exo_file.e> time_step<int> check_vol_change<bool>"
<< std::endl;
