[MOAB-dev] Getting ent set data when tag_size > 1
    Tim Tautges
    tautges at mcs.anl.gov
    Sat Apr 17 17:20:21 CDT 2010
Jed Brown wrote:
> On Fri, 16 Apr 2010 15:27:36 -0500, James Porter <jvporter at wisc.edu> wrote:
>> On Tue, 2010-04-13 at 13:34 -0500, Tim Tautges wrote:
>>> Jed Brown wrote:
>>>> There ought to be get/setEntSetArrData (in fact, I would only expose the
>>>> array interface because the single-tag versions are crippled and not
>>>> more usable).
>>> Agreed.  I'll put that on the list of extensions to write, and will propose it to itaps (nobody else really uses sets in
>>> any serious way, so that's probably why it hasn't come up there).
>> Attached is what I personally would like to see in terms of interface.
>> Main points:
>> * No type-specific functions (uses void* everywhere)
I know already this one won't fly (I opposed it when first proposed, and lost).
>> * get/set functions that take in arrays of entity sets
> Agree
>> * get/set functions for arrays of entities/sets take a storage order
> Why is this necessary?  It seems to me that BLOCKED may as well be
> different tags.  Coordinates are special because they have additional
> meaning and legacy codes/file formats made a suboptimal choice about
> storage.  I'd rather not see this complicate the interface and
> presumably there aren't legacy codes using tags with BLOCKED storage
> (since it's not currently available) and it doesn't make sense to write
> a new code with BLOCKED (ITAPS won't perform well on classic vector
> machines anyway).
I doubt many apps use multi-valued, typed, tags, and those few that do aren't overly burdened by having just interleaved
versions.
> Jed
> (I've mentioned it before, but iMesh_getDfltStorage should really return
> iBase_INTERLEAVED because this is actually MOAB's native format and it
> seems silly to advise users to use a suboptimal representation.)
Actually, it's blocked; see VertexSequence constructor.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
