[MOAB-dev] compilation error with intel compiler
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Fri Apr  9 09:44:29 CDT 2010
Lukasz Kaczmarczyk wrote:
> Hello,
> I use intel compiler and I get compilation error,
> ReadSmf.cpp(38) (col. 29): internal error: assertion failed: be_value_from_constant: unknown constant kind (shared/edgglue/edg_decl.c, line 1243)
> What I can do?
This is a problem with the Intel compiler, not the MOAB code.  You can try
the attached patch as a work-around, but the correct solution is probably to
submit a bug report to Intel if this problem has not yet been reported, and
update the version of the compiler if/when a fix becomes available.
- jason
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100409/0145b1a3/attachment.bin>
