[MOAB-dev] problems reading meshes in MOAB in the 'read_part' mode
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Apr  6 18:11:38 CDT 2010
I'll often use 'mbsize -ll' and pipe the output to a file; this will print all sparse tags on sets, among other things.
- tim
Jason Kraftcheck wrote:
> Dmitry Karpeev wrote:
>> Jason,
>> How did you look at the tags in this file?
>> I mean, is there an easy way to examine the tags on a given mesh file?
> I used the h5dump utility included with the HDF5 library.  It is rather
> low-level.  You might prefer to write your own utility.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
