[MOAB-dev] create ray_intersect_all_sets function
Paul Wilson wilsonp at engr.wisc.edu
Mon Apr 5 22:32:14 CDT 2010
Hi all,
I am not sure how this is different from calling ray_intersect_sets
multiple times, one after the other?  This would march along the ray and
find all the intersections. Is it just a performance issue?
Paul
Hongjun Kim wrote:
> Your patch is working for me.
> Are you going to commit it or do you want me to do it?
> Thanks.
> Hong-Jun
> From: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
> To: hongjun at mcs.anl.gov
> Cc: "Brandon Smith" <bsmith82 at yahoo.com>, moab-dev at mcs.anl.gov
> Sent: Monday, April 5, 2010 3:00:14 PM GMT -06:00 US/Canada Central
> Subject: Re: [MOAB-dev] create ray_intersect_all_sets function
> hongjun at mcs.anl.gov wrote:
>> To find all surface sets intersected (including multiple hits for one
>> surface set), I have to give large tolerance. If it is not, it just find
>> the first intersections for each surface set.
> Specifying a large tolerance to obtain all intersections is a suboptimal
> solution.  You might as well just test all of the triangles against the ray.
> However, rather than adding 200 lines of duplicated functionality, why not
> just fix the existing code such that it can return multiple intersections.
> For example, see the attached patch.
> - jason
> Index: src/OrientedBoxTreeTool.cpp
> --- src/OrientedBoxTreeTool.cpp	(revision 3740)
> +++ src/OrientedBoxTreeTool.cpp	(working copy)
> @@ -950,6 +950,14 @@
>  void RayIntersectSets::add_intersection( double t, EntityHandle facet )
> +    // If minTolInt is less than zero, return all intersections
> +  if (minTolInt < 0 && t > -tol) {
> +    intersections.push_back(t);
> +    sets.push_back(lastSet);
> +    facets.push_back(facet);
> +    return;
>      // Check if the 'len' pointer is pointing into the intersection
>      // list.  If this is the case, then the list contains, at that
>      // location, an intersection greater than the tolerance away from
> Index: src/moab/OrientedBoxTreeTool.hpp
> --- src/moab/OrientedBoxTreeTool.hpp	(revision 3740)
> +++ src/moab/OrientedBoxTreeTool.hpp	(working copy)
> @@ -233,6 +233,9 @@
>       *                     ray start point is less than this number, the next closest
>       *                     intersection.  If the desired result is only the closest
>       *                     intersection, pass zero for this argument.
> +     *                     This function will return all intersections, regardless
> +     *                     of distance from the start of the ray, if this value
> +     *                     is negative.
>       *\param tolerance     The tolerance to use in intersection checks.
>       *\param ray_point     The base point of the ray.
>       *\param unit_ray_dir  The ray direction vector (must be unit length)
Paul Wilson
Paul P.H. Wilson              419 Engineering Research Building
wilsonp at engr.wisc.edu                       1500 Engineering Dr
ph/fax: 608/263-0807                          Madison, WI 53706
           My calendar: http://bit.ly/pphw-calendar
       Computational Nuclear Engineering Research Group
               http://cnerg.engr.wisc.edu
          Associate Professor, Nuclear Engineering
              Engineering Physics Department
               http://www.engr.wisc.edu/ep
        Chair, Energy Analysis & Policy Certificate
         Nelson Institute for Environmental Studies
                http://nelson.wisc.edu/eap/
          Contributing to the joy and improvement
                  of all those around me
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100405/662335b9/attachment.htm>
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100405/662335b9/attachment.bin>
