[MOAB-dev] r3741 - MOAB/trunk/src
kraftche at cae.wisc.edu
Mon Apr 5 12:08:45 CDT 2010
Author: kraftche
Date: 2010-04-05 12:08:45 -0500 (Mon, 05 Apr 2010)
New Revision: 3741
Modified:
MOAB/trunk/src/AdaptiveKDTree.cpp
Log:
More tweaks to kD-tree code:
o Fix possible inadvertent increase in tolerance value used for ray
intersections as tree is descended.
o Increase tolerance used in tree construction even more, because while
false positives might result in a slightly less efficient tree, false
negatives result in incorrect trees.
Modified: MOAB/trunk/src/AdaptiveKDTree.cpp
--- MOAB/trunk/src/AdaptiveKDTree.cpp 2010-04-02 19:15:01 UTC (rev 3740)
+++ MOAB/trunk/src/AdaptiveKDTree.cpp 2010-04-05 17:08:45 UTC (rev 3741)
@@ -797,7 +797,8 @@
const CartVect left_dim = 0.5*(left_max - box_min);
const CartVect right_cen = 0.5*(box_max + right_min);
const CartVect right_dim = 0.5*(box_max - right_min);
- //const CartVect dim = box_max - box_min;
+ const CartVect dim = box_max - box_min;
+ const double max_tol = std::max(dim[0], std::max(dim[1], dim[2]))/10;
// test each entity
@@ -856,9 +857,9 @@
// sides of plane, do more precise test to ensure that it is really
// in both.
if (lo && ro) {
- double tol = eps/1000;
+ double tol = eps;
lo = ro = false;
- while (!lo && !ro && tol <= eps) {
+ while (!lo && !ro && tol <= max_tol) {
lo = GeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen, left_dim+CartVect(tol) );
ro = GeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,right_dim+CartVect(tol) );
tol *= 10.0;
@@ -2091,7 +2092,18 @@
// Otherwise we want the right child (index == 1);
list.push_back( NodeSeg( children[fwd_child], seg.beg, seg.end ) );
- // Otherwise we must intersect the plane
+ // Otherwise we must intersect the plane.
+ // Note: be careful not to grow the segment if t is slightly
+ // outside the current segment, as doing so would effectively
+ // increase the tolerance as we descend the tree.
+ else if (t <= seg.beg) {
+ list.push_back( NodeSeg( children[1-fwd_child], seg.beg, seg.beg ) );
+ list.push_back( NodeSeg( children[ fwd_child], seg.beg, seg.end ) );
+ else if (t >= seg.end) {
+ list.push_back( NodeSeg( children[1-fwd_child], seg.beg, seg.end ) );
+ list.push_back( NodeSeg( children[ fwd_child], seg.end, seg.end ) );
else {
list.push_back( NodeSeg( children[1-fwd_child], seg.beg, t ) );
list.push_back( NodeSeg( children[ fwd_child], t, seg.end ) );
