[MOAB-dev] problems reading meshes in MOAB in the 'read_part'	mode
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Thu Apr  1 16:15:49 CDT 2010
Jason,
How did you look at the tags in this file?
I mean, is there an easy way to examine the tags on a given mesh file?
Thanks.
Dmitry.
On Thu, Apr 1, 2010 at 12:21 PM, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> Dmitry Karpeev wrote:
>> I've run several cases of mbparallelcomm_test with 3 different files
>> on my laptop,
>> and I conclude from the results sketched below that the 'read_part'
>> mode is currently
>> broken.
>> For these runs I used MOAB/trunk rev 3733 and three files:
>> 64bricks_1khex_256.h5m
> I looked at this file.  It contains a definition for a tag named
> 'PARALLEL_PARTITION', but the tag is not set for any entity.  It does have a
> default and global value.  The latter is rather odd.
> - jason
