[MOAB-dev] r3731 - MOAB/trunk/src
kraftche at cae.wisc.edu
Wed Mar 31 09:40:58 CDT 2010
Author: kraftche
Date: 2010-03-31 09:40:58 -0500 (Wed, 31 Mar 2010)
New Revision: 3731
Modified:
MOAB/trunk/src/MBEntityType.h
Log:
o Do not try to define increment/decrement operators for MBEntityType if
included in C (not C++) code.
o Document the slightly confusing preprocessor logic that makes the
moab::EntityType/MBEntityType stuff work.
Modified: MOAB/trunk/src/MBEntityType.h
--- MOAB/trunk/src/MBEntityType.h 2010-03-31 14:20:00 UTC (rev 3730)
+++ MOAB/trunk/src/MBEntityType.h 2010-03-31 14:40:58 UTC (rev 3731)
@@ -22,6 +22,43 @@
* grouped together.
+/* This file can be used to define several different things.
+ * A) If included in C code (not C++), it defines:
+ * 1) An enum named MBEntityType, guarded by the MB_ENTITY_TYPE_H
+ * include guards and
+ * 2) a typedef MBEntityType guarded by MOAB_ENTITY_TYPE_C include guards.
+ * B) If included in C++ code, it defines:
+ * 1) An enum named EntiyType in the MOAB namespace, guarded
+ * by the MB_ENTITY_TYPE include guards
+ * 2) Increment and decrement oeprators for the moab::EntityType enum,
+ * also guarded by the MB_ENTITY_TYPE include guards
+ * 3) A typedef for moab::EntityType in the global namespace
+ * named MBEntityType, guarded by the MOAB_ENTITY_TYPE_NS_ONLY
+ * include guards
+ * The C and C++ code should be entirely independent. They are defined
+ * in the same file only to avoid code duplication and inconsistent enum
+ * values. OTOH, the C++ definitions must be in the same file because
+ * the compiler must treat both the namespaced and non-namespaced names
+ * as the same type.
+ * The C++ code must be able to provide:
+ * a) An enum in the moab namespace
+ * b) An enum in the global namespace that is the *same type*
+ * as a) as far as the compiler is concerned.
+ * c) Nothing in the global namespace unless requested
+ * d) No breakage if both namespaced and non-namespaced headers
+ * are both included.
+ * This is acheived with the somewhat complicated set of multiple
+ * included guards described above, where moab/EntityType.hpp will
+ * include this file with MOAB_ENTITY_TYPE_NS_OLNY temporarily defined
+ * so as to pull in only the namespaced version at that time, without
+ * prohibiting the non-namespaced version from being pulled in previously
+ * or later.
#ifdef __cplusplus
namespace moab {
# define MOAB_ENTITY_TYPE_NAME EntityType
@@ -46,6 +83,7 @@
/**< dimensioning purposes */
+#ifdef __cplusplus
/** prefix increment operator for MBEntityType */
inline MOAB_ENTITY_TYPE_NAME & operator++(MOAB_ENTITY_TYPE_NAME &type)
@@ -74,7 +112,6 @@
return oldval;
-#ifdef __cplusplus
} /* namespace moab*/
#endif /* __cplusplus */
