[MOAB-dev] r3714 - in MOAB/trunk: test/parallel tools/mbzoltan
    tautges at mcs.anl.gov
    Thu Mar 25 17:16:30 CDT 2010
Author: tautges
Date: 2010-03-25 17:16:30 -0500 (Thu, 25 Mar 2010)
New Revision: 3714
Modified:
   MOAB/trunk/test/parallel/mbparallelcomm_test.cpp
   MOAB/trunk/tools/mbzoltan/main.cpp
Log:
Added code to reduce and print number of shared vertices.
Use non-deprecated constructor, and check for file read error.
Modified: MOAB/trunk/test/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/test/parallel/mbparallelcomm_test.cpp	2010-03-25 21:53:00 UTC (rev 3713)
+++ MOAB/trunk/test/parallel/mbparallelcomm_test.cpp	2010-03-25 22:16:30 UTC (rev 3714)
@@ -427,7 +427,7 @@
   ErrorCode result = MB_SUCCESS, tmp_result;
     // now figure out which vertices are shared
-  Range part_ents;
+  Range part_ents, part_verts;
   for (unsigned int p = 0; p < pcs.size(); p++) {
     // get entities owned by this partition
     for (Range::iterator rit = pcs[p]->partition_sets().begin();
@@ -452,6 +452,20 @@
+    // get non-owned vertices
+  result = pcs[0]->get_pstatus_entities(0, PSTATUS_NOT_OWNED, part_verts);
+  if (MB_SUCCESS != tmp_result) {
+    std::cerr << "Couldn't get non-owned entities." << std::endl;
+    return result;
+  int tot_verts;
+  result = mbImpl->get_number_entities_by_dimension(0, 0, tot_verts);
+    std::cerr << "Couldn't get number of vertices." << std::endl;
+    return result;
+  tot_verts -= part_verts.size();
     // report # iface entities
   result = mbImpl->get_adjacencies(iface_ents[4], 0, false, iface_ents[5],
                                    Interface::UNION);
@@ -474,15 +488,19 @@
 	    << " 3d entities." << std::endl;
     // get total # regions over all procs
-  int num_local = part_ents.size(), num_total;
+  int num_local[2], num_total[2];
+  num_local[0] = tot_verts;
+  num_local[1] = part_ents.size();
-  int failure = MPI_Reduce(&num_local, &num_total, 1,
+  int failure = MPI_Reduce(&num_local, &num_total, 2,
                            MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
   if (failure) result = MB_FAILURE;
-  if (0 == rank)
-    std::cout << "Total # owned regions = " << num_total << std::endl;
+  if (0 == rank) {
+    std::cout << "Total # owned vertices = " << num_total[0] << std::endl;
+    std::cout << "Total # owned regions = " << num_total[1] << std::endl;
   return result;
Modified: MOAB/trunk/tools/mbzoltan/main.cpp
--- MOAB/trunk/tools/mbzoltan/main.cpp	2010-03-25 21:53:00 UTC (rev 3713)
+++ MOAB/trunk/tools/mbzoltan/main.cpp	2010-03-25 22:16:30 UTC (rev 3714)
@@ -16,7 +16,15 @@
 #include <iostream>
 #include <string>
-#define RR if (MB_SUCCESS != result) return result
+#define RR                                                            \
+    {if (MB_SUCCESS != result) {                                      \
+        std::string last_error;                                       \
+        mbImpl->get_last_error(last_error);                           \
+        std::cerr << "MOAB returned with error: " << std::endl;       \
+        std::cerr << last_error << std::endl;                         \
+        return 1;                                                     \
 int main(int argc, char *argv[])
@@ -49,10 +57,11 @@
   err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
     // create MOAB instance based on that
-  moab::Interface *mbImpl = new moab::Core(rank, nprocs);
+  moab::Interface *mbImpl = new moab::Core();
   if (NULL == mbImpl) return 1;
   moab::ErrorCode result = mbImpl->load_mesh(argv[2]); RR;
   MBZoltan *mbz = new MBZoltan(mbImpl, false, argc, argv);
