[MOAB-dev] r3693 - MOAB/trunk/examples
hongjun at mcs.anl.gov
Mon Mar 22 18:42:21 CDT 2010
Author: hongjun
Date: 2010-03-22 18:42:20 -0500 (Mon, 22 Mar 2010)
New Revision: 3693
Added:
MOAB/trunk/examples/ObbTree.cpp
Modified:
MOAB/trunk/examples/Makefile.am
Log:
o added a simple obb tree ray tracing example
Modified: MOAB/trunk/examples/Makefile.am
--- MOAB/trunk/examples/Makefile.am 2010-03-22 23:41:19 UTC (rev 3692)
+++ MOAB/trunk/examples/Makefile.am 2010-03-22 23:42:20 UTC (rev 3693)
@@ -2,6 +2,7 @@
GeomSetHierarchy \
GetEntities \
KDTree \
+ ObbTree \
SetsNTags \
SkinMesh \
SurfArea
@@ -18,6 +19,7 @@
SkinMesh_SOURCES = SkinMesh.cpp
SurfArea_SOURCES = SurfArea.cpp
KDTree_SOURCES = KDTree.cpp
+ObbTree_SOURCES = ObbTree.cpp
exampledir = ${docdir}/examples
nobase_example_DATA = \
@@ -27,6 +29,7 @@
simple/GetEntities.cpp \
simple/makefile \
KDTree.cpp \
+ ObbTree.cpp \
SetsNTags.cpp \
SkinMesh.cpp \
SurfArea.cpp
Added: MOAB/trunk/examples/ObbTree.cpp
--- MOAB/trunk/examples/ObbTree.cpp (rev 0)
+++ MOAB/trunk/examples/ObbTree.cpp 2010-03-22 23:42:20 UTC (rev 3693)
@@ -0,0 +1,74 @@
+// simple example construct obb tree and ray-tracing the tree
+// it reads triangle mesh, construct obb tree and get intersection distances
+#include "moab/Core.hpp"
+#include "moab/Range.hpp"
+#include "moab/OrientedBoxTreeTool.hpp"
+#include <iostream>
+#include <math.h>
+int main(int argc, char **argv) {
+ if (1 == argc) {
+ std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
+ return 0;
+ // instantiate & load a mesh from a file
+ moab::Core *mb = new moab::Core();
+ moab::ErrorCode rval = mb->load_mesh(argv[1]);
+ // get all triangles
+ int err;
+ moab::EntityHandle tree_root;
+ moab::Range tris;
+ //moab::OrientedBoxTreeTool::Settings settings;
+ rval = mb->get_entities_by_type( 0, moab::MBTRI, tris );
+ if (rval != moab::MB_SUCCESS) {
+ std::cerr << "Couldn't get triangles." << std::endl;
+ return 1;
+ // build OBB trees for all triangles
+ moab::OrientedBoxTreeTool tool(mb);
+ //rval = tool.build(tris, tree_root, &settings);
+ rval = tool.build(tris, tree_root);
+ std::cerr << "Could'nt build tree." << std::endl;
+ return 1;
+ // build box
+ double box_center[3], box_axis1[3], box_axis2[3], box_axis3[3], start_pnt[3],
+ ray_length;
+ rval = tool.box(tree_root, box_center, box_axis1, box_axis2, box_axis3);
+ std::cerr << "Couldn't get box for tree root set.";
+ return 1;
+ ray_length = 2.*sqrt(box_axis1[0]*box_axis1[0] + box_axis1[1]*box_axis1[1] +
+ box_axis1[2]*box_axis1[2]);
+ // do ray-tracing from box center to x direction
+ std::vector<double> intersections;
+ double dir[3] = {1., 0., 0.};
+ rval = tool.ray_intersect_triangles(intersections, tree_root,
+ 10e-12, box_center, dir,
+ &ray_length);
+ std::cerr << "Couldn't ray tracing.";
+ return 1;
+ std::cout << "ray start point: " << start_pnt[0] << " "
+ << start_pnt[1] << " " << start_pnt[2] << std::endl;
+ std::cout << "# of intersections : " << intersections.size() << std::endl;
+ std::cout << "intersection distances are on";
+ for (int i = 0; i < intersections.size(); i++) {
+ std::cout << " " << intersections[i];
+ std::cout << " of ray length " << ray_length << std::endl;
+ return 0;
