[MOAB-dev] r3682 - in MOAB/trunk/src: . moab
    kraftche at cae.wisc.edu
    Fri Mar 19 19:00:21 CDT 2010
Author: kraftche
Date: 2010-03-19 19:00:20 -0500 (Fri, 19 Mar 2010)
New Revision: 3682
Modified:
   MOAB/trunk/src/BitTagServer.cpp
   MOAB/trunk/src/Core.cpp
   MOAB/trunk/src/MeshSet.hpp
   MOAB/trunk/src/MeshSetSequence.cpp
   MOAB/trunk/src/SequenceManager.cpp
   MOAB/trunk/src/SequenceManager.hpp
   MOAB/trunk/src/SparseTagCollection.cpp
   MOAB/trunk/src/moab/Core.hpp
   MOAB/trunk/src/moab/Interface.hpp
Log:
Make Interface::get_entities_by_type{and_tag} and
Interface::get_number_entities_by_type{and_tag} return
results for all types if type is MBMAXTYPE
A) I'm tired of writing a loop over every type every time I
   want to get all entities with a tag
B) Writing a simple loop isn't necessarily the same thing
   depending on the value of the 'condition' argument
Modified: MOAB/trunk/src/BitTagServer.cpp
--- MOAB/trunk/src/BitTagServer.cpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/BitTagServer.cpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -271,6 +271,9 @@
 ErrorCode BitTag::get_entities( EntityType type, Range& entities ) const
+  if (MBMAXTYPE == type)
+    return get_entities(entities);
   const int per_page = ents_per_page();
   Range::iterator hint = entities.begin();
   for (size_t i = 0; i < pageList[type].size(); ++i) {
@@ -294,12 +297,12 @@
   EntityID count;
   size_t page;
   int offset, per_page = ents_per_page();
-  Range::const_iterator j, i = range.lower_bound( in_type );
+  Range::const_iterator j, i = in_type == MBMAXTYPE ? range.begin() : range.lower_bound( in_type );
   EntityHandle h;
   while (i != range.end()) {
     h = *i;
     unpack( h, type, page, offset );
-    if (type != in_type)
+    if (in_type != MBMAXTYPE && type != in_type)
       break;
     i = i.end_of_block();
@@ -324,6 +327,16 @@
                                             Range& entities,
                                             unsigned char bits ) const
+  if (MBMAXTYPE == type) {
+    ErrorCode rval;
+    for (--type; type >= MBVERTEX; --type) {
+      rval = get_entities_with_bits( type, entities, bits );
+      if (MB_SUCCESS != rval)
+        return rval;
+    return MB_SUCCESS;
     if (pageList[type][i]) {
@@ -342,6 +355,16 @@
                                             Range& entities,
+  if (MBMAXTYPE == in_type) {
+    ErrorCode rval;
+    for (--in_type; in_type >= MBVERTEX; --in_type) {
+      rval = get_entities_with_bits( range, in_type, entities, bits );
+        return rval;
   EntityType type;
   EntityID count;
   size_t page;
@@ -377,8 +400,20 @@
 ErrorCode BitTag::get_number_entities( EntityType type,
                                          int& num_entities ) const
+  num_entities = 0;
+    int tmp;
+    ErrorCode rval;
+      rval = get_number_entities( type, tmp );
+        return rval;
+      num_entities += tmp;
-  num_entities = 0;
   if (pageList[type].empty())
     return MB_SUCCESS;
   if (pageList[type][0])
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/Core.cpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -1666,11 +1666,12 @@
                                                           const void* const* values,
                                                           const int num_tags,
                                                           int &num_entities,
+                                                          int condition,
                                                           const bool recursive) const
   Range dum_ents;
   ErrorCode result = get_entities_by_type_and_tag(meshset, type, tag_handles, values, num_tags,
-                                                     dum_ents, recursive);
+                                                     dum_ents, condition, recursive);
   num_entities = dum_ents.size();
   return result;
Modified: MOAB/trunk/src/MeshSet.hpp
--- MOAB/trunk/src/MeshSet.hpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/MeshSet.hpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -467,7 +467,10 @@
   size_t count;
   const EntityHandle* ptr = get_contents( count );
-  if (vector_based()) {
+    return get_entities( entity_list );
+  else if (vector_based()) {
     std::remove_copy_if( ptr, ptr+count,
                          std::back_inserter( entity_list ),
                          not_type_test(type) );
@@ -500,7 +503,10 @@
   size_t count;
                          range_inserter( entity_list ),
@@ -534,7 +540,10 @@
   unsigned int result;
   size_t count;
+    return num_entities( );
     #ifndef __SUNPRO_CC
       result = std::count_if( ptr, ptr+count, type_test(type) );
     #else
Modified: MOAB/trunk/src/MeshSetSequence.cpp
--- MOAB/trunk/src/MeshSetSequence.cpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/MeshSetSequence.cpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -222,6 +222,13 @@
   else if (type == MBENTITYSET) {
     return recursive_get_sets( handle, seqman, 0, 0, &entities );
+  else if (type == MBMAXTYPE) {
+    Range tmp;
+    ErrorCode rval = get_entities( seqman, handle, tmp, recursive );
+    if (MB_SUCCESS == rval)
+      entities.insert( entities.end(), tmp.begin(), tmp.end() );
+    return rval;
   else {
     std::vector<const MeshSet*> list;
     ErrorCode rval = recursive_get_sets( handle, seqman, &list );
@@ -244,6 +251,13 @@
     return recursive_get_sets( handle, seqman, 0, &entities );
+    std::vector<const MeshSet*> list;
+    ErrorCode rval = recursive_get_sets( handle, seqman, &list );
+    for (std::vector<const MeshSet*>::iterator i = list.begin(); i != list.end(); ++i)
+      (*i)->get_non_set_entities( entities );
+    return rval;
   else {
Modified: MOAB/trunk/src/SequenceManager.cpp
--- MOAB/trunk/src/SequenceManager.cpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/SequenceManager.cpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -117,6 +117,28 @@
     new (typeData+t) TypeSequenceManager();
+void SequenceManager::get_entities( Range& entities_out ) const
+  for (EntityType t = MBENTITYSET; t >= MBVERTEX; --t)
+    typeData[t].get_entities( entities_out );
+void SequenceManager::get_entities( std::vector<EntityHandle>& entities_out ) const
+  for (EntityType t = MBVERTEX; t != MBMAXTYPE; ++t)
+EntityID SequenceManager::get_number_entities( ) const
+  EntityID sum = 0;
+    sum += typeData[t].get_number_entities();
+  return sum;
 ErrorCode SequenceManager::check_valid_entities( const Range& entities ) const
   ErrorCode rval;
@@ -1431,6 +1453,16 @@
   if (tag_id >= tagSizes.size() || !tagSizes[tag_id])
     return MB_TAG_NOT_FOUND;
+  if (type == MBMAXTYPE) {
+    ErrorCode rval;
+    for (EntityType t = MBVERTEX; t < MBMAXTYPE; ++t) {
+      rval = get_tagged_entities( tag_id, t, entities_out );
+        return rval;
   Range::iterator insert = entities_out.begin();
   const TypeSequenceManager& map = entity_map( type );
   if (tagSizes[tag_id] == MB_VARIABLE_LENGTH) {
@@ -1464,6 +1496,19 @@
   count = 0;
+    ErrorCode rval;
+      int tmp = 0;
+      rval = count_tagged_entities( tag_id, t, tmp );
+        return rval;
+      count += tmp;
@@ -1498,6 +1543,16 @@
   if (id >= tagSizes.size() || !tagSizes[id])
+    ErrorCode rval;
+      rval = get_entities_with_tag_value( id, tag_info, t, entities_out, value, size );
+        return rval;
   for (TypeSequenceManager::const_iterator i = map.begin(); i != map.end(); ++i) {
@@ -1525,9 +1580,10 @@
-  Range::const_pair_iterator p = range.lower_bound(type);
+  Range::const_pair_iterator p = type == MBMAXTYPE ? range.begin() : range.lower_bound(type);
   for (Range::const_pair_iterator p = range.const_pair_begin();
-       p != range.const_pair_end() && TYPE_FROM_HANDLE(p->first) == type;
+       p != range.const_pair_end() &&
+       (MBMAXTYPE == type || TYPE_FROM_HANDLE(p->first) == type);
        ++p) {
     EntityHandle start = p->first;
Modified: MOAB/trunk/src/SequenceManager.hpp
--- MOAB/trunk/src/SequenceManager.hpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/SequenceManager.hpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -35,17 +35,36 @@
         return typeData[TYPE_FROM_HANDLE(handle)].find( handle, sequence_out );
-      /** Get all entities of a given EntityType */
-   void get_entities( EntityType type, Range& entities_out ) const
-      { typeData[type].get_entities( entities_out ); }
+      /** Get all entities of a given EntityType, return all entities
+       *  if type == MBMAXTYPE */
+    void get_entities( EntityType type, Range& entities_out ) const
+          get_entities( entities_out );
+        else
+          typeData[type].get_entities( entities_out );
+    void get_entities( Range& entities_out ) const;
-   void get_entities( EntityType type, std::vector<EntityHandle>& entities_out ) const
+    void get_entities( EntityType type, std::vector<EntityHandle>& entities_out ) const
+        else
+    void get_entities( std::vector<EntityHandle>& entities_out ) const;
       /** Count entities of a given EntityType */
     EntityID get_number_entities( EntityType type ) const
-      { return typeData[type].get_number_entities(); }
+      { return type == MBMAXTYPE ? get_number_entities() : typeData[type].get_number_entities(); }
+      /** Count entities of a given EntityType */
+    EntityID get_number_entities( ) const;
       /** Get most recently accessed sequence for a given type */
     const EntitySequence* get_last_accessed_sequence( EntityType type ) const
Modified: MOAB/trunk/src/SparseTagCollection.cpp
--- MOAB/trunk/src/SparseTagCollection.cpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/SparseTagCollection.cpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -183,7 +183,7 @@
   myMapType::iterator iter;
   for(iter = mData.begin(); iter != mData.end(); ++iter)
-    if(TYPE_FROM_HANDLE(iter->first) == type)
+    if(MBMAXTYPE == type || TYPE_FROM_HANDLE(iter->first) == type)
       num_entities++;
   return MB_SUCCESS;
@@ -195,7 +195,7 @@
       entities.insert(iter->first);
   return MB_SUCCESS;
@@ -210,6 +210,18 @@
                                                     const void* tag_value,
                                                     int value_size)
+    ErrorCode rval;
+    while (type--) {
+      rval = get_entities_with_tag_value( tag_info, type, entities, tag_value, value_size );
+        return rval;
   myMapType::iterator iter, end;
 #ifdef HAVE_UNORDERED_MAP
Modified: MOAB/trunk/src/moab/Core.hpp
--- MOAB/trunk/src/moab/Core.hpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/moab/Core.hpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -444,6 +444,7 @@
                                                              const int num_tags,
                                                              int &num_entities,
+                                                             const int condition = Interface::INTERSECT,
                                                              const bool recursive = false) const;
       //! Retrieves all entities in the data base
Modified: MOAB/trunk/src/moab/Interface.hpp
--- MOAB/trunk/src/moab/Interface.hpp	2010-03-19 23:56:57 UTC (rev 3681)
+++ MOAB/trunk/src/moab/Interface.hpp	2010-03-20 00:00:20 UTC (rev 3682)
@@ -772,6 +772,7 @@
                                                           const int num_tags,
                                                           int &num_entities,
                                                           const bool recursive = false) const = 0;
     //! Returns number of entities in the data base or meshset
