[MOAB-dev] make check fails
Tim Tautges tautges at mcs.anl.gov
Thu Mar 18 15:18:49 CDT 2010
I've got a fix in the pipe for the MBTest failure (also one with mbcn_test, but not the MK one below).
- tim
Rajeev Jain wrote:
> make check fails with
> .deps/MBTest.Tpo -c -o MBTest.o MBTest.cpp
> MBTest.cpp: In function ‘moab::ErrorCode
> mb_canon_number_test(moab::Interface*)’:
> MBTest.cpp:5080: error: ‘MB_MAX_SUB_ENTITY_VERTICES’ was not declared in
> this scope
> MBTest.cpp:5084: error: ‘tmp_conn’ was not declared in this scope
> MBTest.cpp:5087: error: ‘tmp_conn’ was not declared in this scope
> also, make sixth in MeshKit fails in CopyMesh.cpp with
> In function `CopyMesh::copy_move_ents(iBase_EntitySetHandle_Private*,
> iBase_TagHandle_Private*)':
> /home/rajeev/FATHOM/source/MeshKit/algs/CopyMesh.cpp:441: undefined
> reference to `imesh_mbcntype_'
> collect2: ld returned 1 exit status
> make[2]: *** [pin217] Error 1
> Rajeev
> Get your preferred Email name!
> <http://sg.rd.yahoo.com/aa/mail/domainchoice/mail/signature/*http://mail.promotions.yahoo.com/newdomains/aa/>
> Now you can @ymail.com and @rocketmail.com.
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
