[MOAB-dev] r3654 - in MOAB/trunk/test: . h5file io obb parallel
    kraftche at cae.wisc.edu
    Wed Mar 17 16:40:46 CDT 2010
Author: kraftche
Date: 2010-03-17 16:40:45 -0500 (Wed, 17 Mar 2010)
New Revision: 3654
Modified:
   MOAB/trunk/test/MBTest.cpp
   MOAB/trunk/test/h5file/h5file_test.cpp
   MOAB/trunk/test/h5file/h5partial.cpp
   MOAB/trunk/test/io/cub_file_test.cc
   MOAB/trunk/test/io/exodus_test.cc
   MOAB/trunk/test/io/gmsh_test.cc
   MOAB/trunk/test/io/nastran_test.cc
   MOAB/trunk/test/obb/obb_test.cpp
   MOAB/trunk/test/parallel/mbparallelcomm_test.cpp
   MOAB/trunk/test/parallel/parallel_hdf5_test.cc
   MOAB/trunk/test/parallel/parallel_unit_tests.cpp
   MOAB/trunk/test/parallel/parallel_write_test.cc
   MOAB/trunk/test/parallel/pcomm_serial.cpp
   MOAB/trunk/test/parallel/pcomm_unit.cpp
   MOAB/trunk/test/parallel/scdtest.cpp
   MOAB/trunk/test/parallel/uber_parallel_test.cpp
Log:
move MBTagConventions.hpp and MBParallelConventions.h back out of moab/ directory because they contain no namespace-d content
Modified: MOAB/trunk/test/MBTest.cpp
--- MOAB/trunk/test/MBTest.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/MBTest.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -36,7 +36,7 @@
 #include <math.h>
 #include <stdio.h>
 #include "moab/Interface.hpp"
-#include "moab/MBTagConventions.hpp"
+#include "MBTagConventions.hpp"
 #include "moab/Range.hpp"
 #include "moab/Skinner.hpp"
 #include "moab/MeshTopoUtil.hpp"
Modified: MOAB/trunk/test/h5file/h5file_test.cpp
--- MOAB/trunk/test/h5file/h5file_test.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/h5file/h5file_test.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -18,7 +18,7 @@
 #include "moab/Core.hpp"
 #include "moab/CN.hpp"
 #define filename "h5test.h5m"
Modified: MOAB/trunk/test/h5file/h5partial.cpp
--- MOAB/trunk/test/h5file/h5partial.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/h5file/h5partial.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -2,7 +2,7 @@
 #include "TestUtil.hpp"
 #include "ReadHDF5.hpp"
 #include "FileOptions.hpp"
 #include <vector>
 #include <stdlib.h>
Modified: MOAB/trunk/test/io/cub_file_test.cc
--- MOAB/trunk/test/io/cub_file_test.cc	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/io/cub_file_test.cc	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,7 +1,7 @@
 #include "Tqdcfr.hpp"
 #include <math.h>
Modified: MOAB/trunk/test/io/exodus_test.cc
--- MOAB/trunk/test/io/exodus_test.cc	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/io/exodus_test.cc	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,6 +1,6 @@
 #define IS_BUILDING_MB
 #include "ReadNCDF.hpp"
Modified: MOAB/trunk/test/io/gmsh_test.cc
--- MOAB/trunk/test/io/gmsh_test.cc	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/io/gmsh_test.cc	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,6 +1,6 @@
 #include "ReadGmsh.hpp"
 #include <math.h>
Modified: MOAB/trunk/test/io/nastran_test.cc
--- MOAB/trunk/test/io/nastran_test.cc	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/io/nastran_test.cc	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,6 +1,6 @@
 #include "ReadNASTRAN.hpp"
Modified: MOAB/trunk/test/obb/obb_test.cpp
--- MOAB/trunk/test/obb/obb_test.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/obb/obb_test.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -2,7 +2,7 @@
 #include "moab/OrientedBoxTreeTool.hpp"
 #include "OrientedBox.hpp"
 #include "moab/GeomUtil.hpp"
Modified: MOAB/trunk/test/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/test/parallel/mbparallelcomm_test.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/mbparallelcomm_test.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -7,10 +7,10 @@
 #include "moab/ParallelComm.hpp"
-#include "moab/MBParallelConventions.h"
+#include "MBParallelConventions.h"
 #include "ReadParallel.hpp"
 #include "ScdVertexData.hpp"
 #include "StructuredElementSeq.hpp"
Modified: MOAB/trunk/test/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/test/parallel/parallel_hdf5_test.cc	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/parallel_hdf5_test.cc	2010-03-17 21:40:45 UTC (rev 3654)
@@ -3,9 +3,9 @@
 #include <iostream>
 #include <sstream>
Modified: MOAB/trunk/test/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/test/parallel/parallel_unit_tests.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/parallel_unit_tests.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,8 +1,8 @@
 #include "moab_mpi.h"
 #include <iostream>
Modified: MOAB/trunk/test/parallel/parallel_write_test.cc
--- MOAB/trunk/test/parallel/parallel_write_test.cc	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/parallel_write_test.cc	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include <iostream>
Modified: MOAB/trunk/test/parallel/pcomm_serial.cpp
--- MOAB/trunk/test/parallel/pcomm_serial.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/pcomm_serial.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,6 +1,6 @@
Modified: MOAB/trunk/test/parallel/pcomm_unit.cpp
--- MOAB/trunk/test/parallel/pcomm_unit.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/pcomm_unit.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,6 +1,6 @@
Modified: MOAB/trunk/test/parallel/scdtest.cpp
--- MOAB/trunk/test/parallel/scdtest.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/scdtest.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -6,8 +6,8 @@
 #include "moab/HomXform.hpp"
 using namespace std;
 using namespace moab;
Modified: MOAB/trunk/test/parallel/uber_parallel_test.cpp
--- MOAB/trunk/test/parallel/uber_parallel_test.cpp	2010-03-17 21:40:37 UTC (rev 3653)
+++ MOAB/trunk/test/parallel/uber_parallel_test.cpp	2010-03-17 21:40:45 UTC (rev 3654)
@@ -1,8 +1,8 @@
 #include <iostream>
