[MOAB-dev] r3641 - in MOAB/trunk/src: . moab
kraftche at cae.wisc.edu
Wed Mar 17 11:00:29 CDT 2010
Author: kraftche
Date: 2010-03-17 11:00:29 -0500 (Wed, 17 Mar 2010)
New Revision: 3641
Modified:
MOAB/trunk/src/OrientedBoxTreeTool.cpp
MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
Log:
make function that passes back a moab::OrientedBox private, as that is not part of the moab API
Modified: MOAB/trunk/src/OrientedBoxTreeTool.cpp
--- MOAB/trunk/src/OrientedBoxTreeTool.cpp 2010-03-17 01:34:30 UTC (rev 3640)
+++ MOAB/trunk/src/OrientedBoxTreeTool.cpp 2010-03-17 16:00:29 UTC (rev 3641)
@@ -1732,7 +1732,7 @@
-static ErrorCode recursive_stats( OrientedBoxTreeTool* tool,
+ErrorCode OrientedBoxTreeTool::recursive_stats( OrientedBoxTreeTool* tool,
Interface* instance,
EntityHandle set,
int depth,
Modified: MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
--- MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp 2010-03-17 01:34:30 UTC (rev 3640)
+++ MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp 2010-03-17 16:00:29 UTC (rev 3641)
@@ -31,6 +31,8 @@
class Range;
class OrientedBox;
+class StatData;
+class CartVect;
class OrientedBoxTreeTool
@@ -300,13 +302,6 @@
* Get the oriented box for a node in an oriented bounding box tree.
ErrorCode box( EntityHandle node_set,
- OrientedBox& box );
- /**\brief Get oriented box at node in tree
- * Get the oriented box for a node in an oriented bounding box tree.
- ErrorCode box( EntityHandle node_set,
double center[3],
double axis1[3],
double axis2[3],
@@ -404,6 +399,17 @@
struct SetData;
private:
+ friend class RayIntersector;
+ friend class TreeNodePrinter;
+ friend class RayIntersectSets;
+ /**\brief Get oriented box at node in tree
+ * Get the oriented box for a node in an oriented bounding box tree.
+ ErrorCode box( EntityHandle node_set,
+ OrientedBox& box );
ErrorCode build_tree( const Range& entities,
EntityHandle& set,
int depth,
@@ -413,6 +419,14 @@
EntityHandle& node_set,
int depth,
const Settings& settings );
+ ErrorCode recursive_stats( OrientedBoxTreeTool* tool,
+ Interface* instance,
+ EntityHandle set,
+ int depth,
+ StatData& data,
+ unsigned& count_out,
+ CartVect& dimensions_out );
Interface* instance;
Tag tagHandle;
