[MOAB-dev] r3635 - MOAB/trunk/examples/SurfArea
jain at mcs.anl.gov
jain at mcs.anl.gov
Tue Mar 16 16:04:00 CDT 2010
Author: jain
Date: 2010-03-16 16:04:00 -0500 (Tue, 16 Mar 2010)
New Revision: 3635
Added:
MOAB/trunk/examples/SurfArea/Makefile
MOAB/trunk/examples/SurfArea/SurfArea.cpp
Log:
o surface area example
Added: MOAB/trunk/examples/SurfArea/Makefile
--- MOAB/trunk/examples/SurfArea/Makefile (rev 0)
+++ MOAB/trunk/examples/SurfArea/Makefile 2010-03-16 21:04:00 UTC (rev 3635)
@@ -0,0 +1,8 @@
+include ${MOAB_LIB_DIR}/moab.make
+SurfArea : SurfArea.o
+ ${CXX} $< ${MOAB_LIBS_LINK} -o $@
+.cpp.o :
+ ${CXX} ${MOAB_INCLUDES} -c $<
Added: MOAB/trunk/examples/SurfArea/SurfArea.cpp
--- MOAB/trunk/examples/SurfArea/SurfArea.cpp (rev 0)
+++ MOAB/trunk/examples/SurfArea/SurfArea.cpp 2010-03-16 21:04:00 UTC (rev 3635)
@@ -0,0 +1,117 @@
+ This example takes a .cub mesh file as input and prints out the total area of
+ meshes in each surface of the model. It works for tri and quad elements.
+ It makes use of CUBIT's reserved tag - GEOM_DIMENSION and GLOBAL_ID tag.
+ Both GLOBAL_ID & GEOM_DIMENSION tag are associated with all the geometric
+ entities in a .cub file. Note: The program would give incorrect result for a
+ non-convex element, since it breaks polygons into triangles for computing the area
+#include "moab/MBCore.hpp"
+#include "moab/MBRange.hpp"
+#include "MBCartVect.hpp"
+#include <iostream>
+double compute_area(std::vector<MBEntityHandle>&);
+// instantiate
+MBInterface *mb;
+int main(int argc, char **argv) {
+ if (1 == argc) {
+ std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
+ return 0;
+ // get tag
+ MBTag gtag, idtag;
+ MBErrorCode rval;
+ const char *tag_geom = "GEOM_DIMENSION";
+ const char *tag_gid = "GLOBAL_ID";
+ MBRange sets;
+ std::vector<MBEntityHandle> ents;
+ // load a file
+ mb = new MBCore();
+ rval = mb->load_file(argv[1]);
+ // get the tag handle for the tags
+ rval = mb->tag_get_handle(tag_geom, gtag);
+ rval = mb->tag_get_handle(tag_gid, idtag);
+ // get all the sets with GEOM_DIMESION tag
+ rval = mb->get_entities_by_type_and_tag(0, MBENTITYSET, >ag,
+ NULL, 1, sets);
+ // iterate over each set, getting entities
+ MBRange::iterator set_it;
+ // loop thru all the geometric entity sets
+ for (set_it = sets.begin(); set_it != sets.end(); set_it++) {
+ MBEntityHandle this_set = *set_it;
+ // get the id for this set
+ int set_id;
+ rval = mb->tag_get_data(gtag, &this_set, 1, &set_id);
+ // check if it is a surface entities (GEOM_DIMENSION 2) then compute area
+ if (set_id ==2){
+ // area of a surface
+ double total_area=0.0;
+ //get the global id of this surface
+ int gid = 0;
+ rval = mb->tag_get_data(idtag, &this_set, 1, &gid);
+ // get all entities with dimension 2 in ents
+ rval = mb->get_entities_by_dimension(this_set, 2, ents);
+ // compute the area
+ total_area = compute_area(ents);
+ ents.clear();
+ std::cout << "Total area of meshes in surface " << gid << " = " << total_area << std::endl;
+// This routine takes all the element entities in a face as input and computes the surface area
+// iterating over each element
+double compute_area(std::vector<MBEntityHandle> & entities){
+ int rval= 0;
+ double area = 0.0;
+ double coord[9];
+ // loop thro' all the elements
+ for (int i=0;i<entities.size();i++){
+ std::vector<MBEntityHandle> conn;
+ MBEntityHandle handle = entities[i];
+ // get the connectivity of this element
+ rval = mb->get_connectivity(&handle, 1, conn);
+ // break polygon into triangles and sum the area - Limitation: Convex polygon
+ for (int j = 2; j<=conn.size(); ++j){
+ MBEntityHandle vertices[3]={conn[0], conn[j-1], conn[j-2]};
+ MBCartVect coords[3];
+ // get 3 coordinates forming the triangle
+ rval = mb->get_coords(vertices, 3, coords[0].array());
+ MBCartVect edge0 = coords[1] - coords [0];
+ MBCartVect edge1 = coords [2] - coords[0];
+ // using MBCarVect overloaded operators and computing triangle area
+ area+=(edge0*edge1).length()/2.0;
+ // clear the entities, else old entities remain
+ entities.clear();
+ return area;
