[MOAB-dev] r3631 - MOAB/trunk
    smithrm at mcs.anl.gov
    Tue Mar 16 10:57:10 CDT 2010
Author: smithrm
Date: 2010-03-16 10:57:10 -0500 (Tue, 16 Mar 2010)
New Revision: 3631
Added:
   MOAB/trunk/KNOWN_ISSUES
Log:
List of known issues for MOAB v4.  This is the initial listing.  It could change before the actual release.
Added: MOAB/trunk/KNOWN_ISSUES
--- MOAB/trunk/KNOWN_ISSUES	                        (rev 0)
+++ MOAB/trunk/KNOWN_ISSUES	2010-03-16 15:57:10 UTC (rev 3631)
@@ -0,0 +1,80 @@
+This is a list of the known issues with MOAB v4.  For more details please see
+the online ticket system at the MOAB website:
+    https://trac.mcs.anl.gov/projects/ITAPS/wiki
+#   Severity  Summary/Details
+33  critical  Parallel read failure for > 32procs
+34  critical  Resolve shared entities bug in scdtest
+6   major     ncdf load failure
+9   major     MOAB has trouble loading the attached files
+10  major     "For ilcend.cub, MOAB returns inconsistent numbers of VERTEXes for
+              REGIONs, FACEs, etc"
+11  major     Get the wrong number of lower/higher dimensional entities for a
+              given entity with ilcend.cub
+28  major     Adjacencies not right after entity creation
+35  major     MOAB parallel memory leak
+144 major     Document need for MPI/IO for HDF5
+149 major     Usage notes for iMesh/iGeom on MOAB/CGM implementations
+151 major     Document usage of parallel moab with non-world communicators
+13  minor     MOAB make check fails w/ clean build & no previous iMesh
+22  minor     iMesh_getAdjTable() is incorrect
+29  minor     Specifying sets not to write
+30  minor     geometric vertex sets not partitioned
+32  minor     support writing compressed (szip) HDF5 files
+37  minor     Bug: MBInterface::merge_entities
+138 minor     Error handlers
+141 minor     reader/writer file set
+142 minor     Document use of MBReaderWriterSet
+145 minor     Remove mbchaco
+148 minor     scdtest.cpp needs more verbose error output
+157 minor     parallel/uber_parallel_test.cpp has typo in file options
+26  trivial   pipelining utilities
